Re. new ballast for Toshiba 52HM84: I purchased it from Conns - Toshiba 23122468 Lamp Ballast, $114.95. Could not find it any cheaper. Thanks for all the tips - they all helped. It was not an easy task. 14 screws to take off the back cover. 3 screws to release the vertical steel support strip. 2 screws to release the light engine tray. 4 screws to take off the cover on the left. 2 screws to release the screws on the left tray. As Mirwin101 said, needed to pull out both the trays since the cable clearances were not enough and rest them on a table of similar height. Now you can access the ballast board. The ballast board pops out real easily (has plastic clips on four corners) but replacing the cable to the light bulb was a pain since it required the steel frame holding the connector to the light bulb to be opened, to release it (2 more screws, difficult to access). Then you do the whole thing in reverse. Note: The TV does not power up until the light bulb door is closed. I landed up with two extra screws when I was done - hopefully the TV will not miss them too badly!! Saved $400! Thanks everyone.
Regards, Naren
Regards, Naren
