AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Bluray Player for CRT Projector
post #1 of 5
I am putting together a blended CRT projector rig. The blender (Analog Way Diventx DVX-8022) has 8 inputs, including DVI, component, RGBHV, and HDSDI. There is no HDMI input on the DVX-8022. I would like to feed the DVX-8022 a 1080P signal. Is there a Bluray player that puts out 1080P over DVI, component, RGBHV or HDSDI?
If not, what other solution would I have to get a 1080P signal into the DVX-8022?
post #2 of 5
I think most BD players can output 1080p, with a HDMI-DVI converter cable. However, you wouldn't be able to get HDMI audio, since it would be in DVI backwards compatibility mode.
post #3 of 5
HD SDI is what you need
-Gary
post #4 of 5
i would think that without HDCP capability, he will get nothing on his CRT.
post #5 of 5
I don't think that getting HDMI audio is much of a concern. I plan to take either 5.1 or 7.1 analog audio out of the player, and send it directly to the audio processor.
