AVS › AVS Forum › Gaming & Content Streaming › HD Radio › HD Radio Isn't High Definition!
HD Radio Isn't High Definition! - Page 3
post #61 of 277
And what's wrong with a subjective conclusion? It's not going to get published in an AES journal, but it may lead you to additional enjoyment of recorded music. I have no problem with a personal conclusion...yours at 77 years of age or mine at 54. I would simply encourage you and others to listen to a REAL 96 kHz/24-bit recording done in the fashion that I've outlined before dismissing the experience out of hand. You might be surprised at what your ears can hear...
As I sit here this morning finishing a paper that will be published in the journal as part of the AES 31 International conference proceedings to he held in London at the end of June, I encouraged that alternative and innovative approaches to audio recordings are being fostered within the organization. My paper is entitled, "CREATING AND DELIVERING HIGH-RESOLUTION MULTIPLE 5.1 SURROUND MUSIC MIXES". It will delivered in conjunction with a series of demonstrations...I look forward to the subjective conclusions that will be offered following the presentations.
post #62 of 277
The dynamic range of a recording can ecplise 90 dB, for example a rim shot or orchestral tutti fortissimo. All I'm asking is that you experience a recording with these parameters on a good system and listen for yourself. If you hear nothing better than what you're used to then no harm no foul...but if the sound is somehow more compelling and expressive, then your subjective conclusion might cause you to seek out recordings done in this fashion.
post #63 of 277
Your request that I listen is fair and reasonable but my high-end audio system does not have a source component for 96/24. Since virtually all the recordings that I like are recorded in 2 channels on a standard CD, I have not upgraded to multichannel audio. (I only acquire recordings that I like in the highest quality available.) All my audio system purchases are based on valid scientific data as well as auditions which explains why I was interested in a double-blind test and was not interested in doing my own test. A prime example is ultra expensive speaker cables which have been proven no better than 12 gauge copper wire which is what I use.
Richard
post #64 of 277
Originally Posted by Dr. AIX View Post
There really isn't a standard definition CD of the track available as a commercial product. Much as you and others of this list believe in compact discs at 44.1 kHz/16-bits...I do not and therefore do not release CD versions of our content.
Interesting that you go out of your way to keep these recordings off of the most popular music format in the world because you don't "believe in compact discs". Almost everyone (including almost all audiophiles) believe 44.1 Khz/16 bit PCM is the ultimate format. It seems like you have to "believe" in a format for it to sound good.
Because subjective conclusions are often false conclusions.
Take a recording and crank up the highs. People will say it sounds better than the original recording. Tell them it sounds better because it's HD Audio or Monster cables or whatever. They'll believe you.
post #65 of 277
Or you can hook up a BOSE 3-2-1 system for someone that is only listening to movies on their TV speakers and they will think it is because of Bose, and not because their TV speakers are just inadequate.
post #66 of 277
I realize my recordings are not for everyone...including audiophiles that are completely content with the sound of compact discs. If you read some of the postings over the AVS Surround Music section...you might get a glimpse of the enthusiasm for our work.
You won't know until you hear it in HD 5.1 Surround...if you do you'll know there's more to hear.
post #67 of 277
On 10/30/2004 Boston Audio Society ran a double-blind comparison test between 24bit/96khz high resolution audio and 16bit/44.1 CD quality, an ABX test. As a member I could not find the results and I wrote to the President and he advised as follows:
"Summary-Correct responses were less than chance. Brad will eventually write it up. It will appear in the AES JOURNAL 1st."
This supports what MIKE WALKER, SCOWL, MATTDP, myself and others have stated. Under controlled conditions you cannot hear any difference.
These results should not be dismissed since BOSTON AUDIO SOCIETY is a highly regarded organization with outstanding credentials.
Richard
post #68 of 277
And Dr AIX if you think the rim shot is 90 db louder, even at it's loudest peak, than the noise level in the room, you're delusional. Hell dude, this can actually be measured. SHOW US A SCOPE PHOTO, accompanied by a .wav file of the rim shot that's 90 db higher than the noise level.
If the volume control is advanced so that the noise floor is just audible, and a peak comes along that is 90 db louder, it will either be deafeningly loud, or (more likely) the amplifier will clip (even with efficient speakers this would require thousands of watts), or the tweeters will be fried. NOBODY is actually reproducing 96db dynamic range at present! And if recordings actually did have this much dynamic range, people would take them back and demand a refund, because the average level would be so damn low!
Those of us who have actually viewed uncompressed waveforms on a scope or computer screen ain't falling for the "music has greater than 90db dynamic range" silliness. 'Tain't so, and if it was, most people wouldn't want it in their listening room! REAL homes aren't quiet enough to hear anything recorded that low, and real amplifiers and speakers aren't up to reproducing anything that dynamic.
post #69 of 277
You may be content listening to music that is highly processed and dynamically adjusted to fit the limitations of the recording or to make it more commercially viable...that's your choice. As a former mastering engineer [16 years of mastering CDs for the major labels and others], there is a difference between recordings that leave the dynamics alone and those that don't. My recording of the Ravel Bolero was faulted by Absolute Sound magazine because there was too much dynamic range. Apparently, the pianissimo of the barely audible snare of the opening to the full tutti of the final passages, which I accurately captured, eclipsed the noise level in the listeners system.
I prefer to leave the dynamics alone and no process them amplitude peaks. If you're saying that a live performance of the Great Gates of Kiev or the finale of the Firebird Suite doesn't get any louder than 90 dB SPL then the derisive term you employed might be more appropriate elsewhere.
HD Audio systems can deliver amplitudes and frequency response that equal or approach the parameters of a lilve event...including the examples mentioned above. I simply do not accept that I have to limit my listening and my recordings to the restrictions of a 25-year old format. Music deserves better.
Have you actually heard an AIX Records recording?
post #70 of 277
Yes, don't we need an amplifier that can generate a 96db sound to enjoy this expanded dynamic range? That's not difficult for headphones of course, but sounds that loud could start to wreck your hearing.
post #71 of 277
Dr Aix, with due respect, you DID NOT PROVE that any recording of yours actually has a 90db range between the noise floor and the loudest sound. THAT is what you claimed, and THAT is what I asked you to prove.
Since homes are seldom quiet enough, amplifiers seldom powerful enough, and speakers seldome robust enough to handle such wide dynamic swings should they exist, I assert that it's actually possible to have too much dynamic range in a recording. GASP, I dared to state the obvious. If quiet passages disappear below the ambient noise in my room, while loud passages are at the threshold of pain, it sure doesn't represent anything I've ever heard live. And being a trumpet player who used to play in a symphony orchestra (though not a famous one), I'm quite familiar with what music actually sounds like live.
IMHO, an engineer who strives to extend the dynamic range of a recording beyond what is either audible or tolerable in a concert hall is the audiophile's version of masturbation. He isn't doing anything for anyone else, but as long as it makes him feel good!
Want to do something worthwhile? MAKE RECORDINGS THAT SOUND GOOD IN MY ROOM, under the conditions that actually exist in people's homes! DUH!
post #72 of 277
Mike, I did not set out to prove anything merely assert that 24-bit digital PCM can capture better dynamics than 16-bits AND that dynamic range is important in music. Measured dynamic range for live sound sources that are musical and not painful...can regularly and do exceed SPL of 90 dB for moments. As a trumpeter sitting right in front of the trombones and horns, I would have guessed that you've experienced this. In the end, all that counts is the dynamics range not the absolute amplitude of your system or mine.
I'm not talking about extending the dynamic range of a recordings...only trying to match the reality of real acoustic energy with the recording systems and playback situation. And I can report that the result is better fidelity. Raul Pineda, a Grammy winning drummer, came to the studio a couple of weeks ago to hear a rough mix of a project I'm doing with his group. They've also been working on a studio recording for CD over the past 8 months. After the first tune in HD 5.1 surround, he turned to his management and said that the AIX Records track was "better than the CD...by far!", They've had been mixing for the past 2 months and our 5 hour session and rough mix knocked him out. He could hardly believe the realism, the dynamics, the details etc.
If you heard this recording or any of our tracks in your space, I'm sure you would relate something similar...the proof is in the experience.
I would encourage you to actually listen to a track done in this fashion...if there is nothing of merit in the experience, then move on. I have been doing these recordings for 7 years and customers and reviewers claim they are among the best they've ever heard. I would venture to say that they will sound amazing in your system in stereo or multichannel.
post #73 of 277
Look, I admit that 24 bits/96khz captures more information than 16/44.1, and that it's important to capture as much information on the recording end as possible. Especially since today's technology makes it relatively simple to do so. Where we differ is in whether this extra information has any importance to listeners in real rooms, on real speakers, at the end of real amplifiers, with the ambient noise levels present in people's homes. There's certainly no harm!
Where audiophiles drive me freakin' nuts is when they start changing the language from "dynamic range' to "acoustic energy", and using all the fruity, tasty language to describe what is simply the pressurization and depressurization of air. That is, after all, all that sound is. ALL sound has only three components...amplitude, frequency, and phase/polarity. That's it. The rest exists between our ears! There's nothing "magic" about it! Shhhhh, don't tell any of your audiophile friends! If they learn the truth, that the only differences POSSIBLE are those of either frequency, amplitude, or polarity/phase, then they're going to feel cheated out of the thousands of dollars they paid for "magic" from their systems
By the way...the above is a generalization, and of course it's not fair. I don't mean to dismiss your work, especially since I haven't heard it. That's cruel, and hurtful, and I would hate it if you did the same to my work. The above is simply my experience based upon my experiences to date. I could change my mind. I have before! Friends?
The only real magic is produced by the performers...in the music itself. The best a recording can do is stay out of the freakin' way! Ditto an audio system. Don't make "magic". LET ME HEAR THE RECORDING!
Sorry to be so dramatic, but I'm a "recovering audiophile", studio owner (mostly radio production, with some audio for video and voiceover work), and musician. I KNOW WHAT SOUNDS REAL, and what's simply b.s. The idea that 90db dynamic range is even desirable is, well, BS!
post #74 of 277
Your reaction seems a bit over the top...but in all honesty, I don't think we disagree on as much as you might suppose. I don't consider myself an audiophile...so I gues I don't have to recover. I've experienced too many people telling me I can improve the sound of my discs by passing them under a special light, waving them over a secret wooden box or piling quartz sand on top of them...I'm not one of those tweaks.
You're perfectly right about the parameters of sound, I teach acoustics at a local university and had pyschoacoustics as one of my doctorate subjects at UCLA back in the 1980s. Dynamic range or acoustic energy...I'm not trying to confuse the situation at all. Just trying to make and distribute the best recordings that I can make.
You don't have to apologize for being passionate about your positions....obviously I am as well. I'll send you one of our samplers...take a listen to Bobby Rodrieguez playing the trumpet on Steve March Tormés track...this is among the best trumpet recordigs that I ever done. There are lots of other tracks that show off the amplitude accuracy of the performances that I've captured.
Once you hear what I'm talking about, you might....just might agree that I've got something special going on. Write me a private message and I'll send you our award winning sampler at my expense. Fair enough?
post #75 of 277
Now see. . . That is what I am talking about. . . We can all be passionate about our positions and still show the love.
post #76 of 277
Ain't it the truth, Master. Thanks Dr. AIX for "showing the love". I hope to be able to repay the kindness in the future.
post #77 of 277
Dr. AIX seems incredibly diplomatic. I still wouldn't buy his snake oil but I don't mind the way he tries to sell it.
post #78 of 277
If I was trying to sell "snake oil" as you put it, the CEA, Surround Music Awards, Leonard Maltin, Electronic House Magazine and others would not have given us their highest awards...my particular "snake oil" actually can but the spring back in your step. Sadly it hasn't done a thing for my balding head...but I can live with that.
post #79 of 277
I won't call it "snake oil", but I would say that just because "other people" say it's good, doesn't mean it is. I can point out hundreds of doctors that reccomended cigarettes as a good thing. . . Does it make it true?
There are several "IBOC haters" out there that look only at the numbers and don't listen to the sound and bash it for being a scam. I think the argument is similar. I have never heard High-Definition Audio, and can not say, but judging by only the numbers is a faulty test. Objective is important, yes, but when combined with subjective judgment can be the most effective.
I don't care that my 3Mb/s high-speed connection is "faster" than the 1.5MB/s, I happen to know, based on my experience that I have a harder time playing my online games since I upgraded to the higher speed. . . Does that make my subjective test flawed?
post #80 of 277
For some reason when I upgraded from 3mbps to 5mbps, the most noticable jump in performance was on my Dell Axim x51v PocketPC, which only has 802.11b. It makes no sense, but web pages load faster, and audio and video stream much more reliably. Sometimes the differences we expect, and what we actually experience, are quite different!
post #81 of 277
Why not? These are not unbiased third parties. These organizations all benefit from promoting new audio formats (except Leonard Maltin who would never sway my opinion). Awards do not change facts.
post #82 of 277
I'm certainly not as cynical as you are regarding panels of judges...they were presented with finalists and sat and listened to them in a high end room. You're right that awards do not change facts...in this case they don't need to...but refusal to listen to a legitimate HD Audio titles yet conintue to pontificate on the merits of something you've not heard...is somehow more telling? I'm sorry I don't think so.
post #83 of 277
I actually heard IBOC on the MW side and it sounds like crap on the stations that have it in our area. FM sounds no different or like a internet audio stream on some stations that have multple feeds (ie HD-2,etc). I heard it in a rental car that had an IBOC tuner and the HDT-1 I got for my b-day.
Originally Posted by milehighmike View Post
I notice the biggest difference on the AM side of the house. Gone is the static, hum, electrical interference, etc. Crisp and clear. On the FM side, I think the biggest benefit is the additional subchannel programming and no commercials (at least thru 2007). I can't really notice much difference between analog and digital FM sound quality wise. It might be because I'm old enough where I probably can't hear any frequency over 15 K !
post #84 of 277
I'm sure your recordings did sound great, but it all comes back to... how would they have sounded on old fashioned CD format? I suspect if they had been listening to CD's they also would have won awards.
Well, my ears aren't that good, I guess. I don't listen to things at 96db on purpose and Mike Walker proved I'm deaf somewhere around 17 Khz so you're not selling me anything I can use. In fact the old CD format exceeds the range of my hearing!
Do you really think people should be listening to music at 100+db? That's the equivalent sound pressure of a jackhammer at one meter! Do you think kids should start listening to their music this loud so they can appreciate HD Audio (for a while anyway)?
BTW, isn't Leonard Maltin a film critic? When did he start giving out audio awards?
post #85 of 277
DR. AIX,
Surround sound recordings can be two original recorded channels(stereo) processed into multiple matrix channels as well as four or more original recorded discrete channels. Where do your recordings fit in? I'm trying to comprehend what you are doing with surround sound.
Richard
post #86 of 277
Nobody's asking that you listen to something at 96 dB SPL or at 100 dB SPL plus..the relative dynamic range is different from the absolute SPL...that's what the deciBel non linear scale is all about. Listen at what is comfortable for you...but pay attention to the dynamics of drums and other quick transients.
Yes, they sounded quite good at CD resolution...but they sound better at high resolution. Leonard Maltin is the host of a DVD Awards program that gives awards for movie DVDs AND for music products. AIX Records has won more of the music awards than any other label...large or small.
As for the questions about matrixed surround from two channels in the style of Dolby Pro Logic or Pro Logic II vs. discrete tracks...I favor real 5.1 surround channels. I record the ensembles in a live hall, mic the back of the room and all of the instrumentalists. I use a large number of stereo pairs and then distribute the audio among the 5.1 array in three different ways. A stage mix puts you among the musicians, the audience mix puts you in the best seat in the house and the stereo mix puts you in front of the band. You choose whatever you want.
post #87 of 277
But Dr. AIX I would add that the USEFUL dynamic range for listeners is a function of the ambient noise level in the room, the power of their amplifier, sensitivity of their speakers, and their tolerance for high SPLs.
Useful dynamic range will ALWAYS be less than 96db in a real room in a real home. Which is why PLAYBACK FORMATS (as opposed to recording or archiving formats, which SHOULD preserve more information than the final product) with greater dynamic range than 96db seem kind of silly...mostly a way (I've always believed) of stopping the practice of "cd ripping", while trying to convince the public they're receiving a "benefit". THEY ARE NOT (IMHO)!
post #88 of 277
Mike...no disagreement in the general systems that are available. But remember you can always scale down, you cannot scale back up. So having the widest possible recording as close to the real thing as possible may only be realized by high end systems. My little label doesn't compromise for the average consumer but for those interested in the high end.
Have you received the sampler?
post #89 of 277
Dr. AIX
Your work in producing quality audio is appreciated. I feel your CD'S do sound better than standard stereo CD'S since you produce quality surround sound discrete channels as opposed to those surround sound CD'S that are nothing more than matrix channels from stereo CD's. As proven by double-blind tests you cannot hear the difference between 44.1/16 and 96/24 playback but for recording purposes 96/24 is preferred.
Richard
post #90 of 277
Thanks...although I think you meant to refer to DVDs not CDs in your comments. I'm currently investigating the literature on the 44.1/16 vs. 96 kHz/24-bit debate...I'm not prepared to agree that I cannot tell the difference in my room with my recordings. Maybe it's time for another investigation. I'm troubled by the testing that's been done that the recordings themselves aren't up to the HD standard. One done when DVD-Audio was first introduced used an analog recording that was transferred to a CD and then captured again at 96/24...and evaulated.
John Calder of Minnetonka produced a disc called the "Resolution Project" that attempted to demonstrate the fidelity of various standards...and it's pretty good but again, I have problems with the methodology of the recordings. These were done in a studio with artificial reverb and processed.
I would like to take a seperate feed of the mics during one of our sessions and send it to a multi-track recorder. Then apply exactly the same mixing parameters [balance and panning only!] to the output. This might be a fruitful approach.
The only tests that I've done used a piece of our content with lots of high frequency metal [percussion - wind chimes and cymbals] that I downconverted from 96 kHz/24-bits to CD standard. I was hoping to supply some of our content to CD-based demo rooms at last summers HE 2006 show. The CD version sounded terrific but lacked in the highest frequencies as compared to the CD. The uppermost sparkle was diminished.
A rigorous test should be done...but until time and resources are available. After having worked with many hundreds of tracks in HD Audio during production and mixing...I remain convinced.
  Back to Forum: HD Radio
