Originally Posted by rjeffb
>>>Thanks folks, nice to be back just in time for New Years. I must say, Windows 7 64 just plain sucks when it comes to surround sound, a huge step backwards....<<<<br />
>>>Because I have not read all the XL3 owners abandoning Win7 I presume that this is not a major problem with the built-in onboard sound chip but boy, reading reviews of various add-on cards I see almost nothing but complaints under 64 bit Windows 7.<<<
Hi Jeff. Wow, "sounds" like the Gremlins have got you down (pun intended). I didn't use SPDIF in Windows 7 64-bit. I encounter no sound issues just using the HDMI out to my Sony tuner/receiver and pass-through to HDTV. Wish I could help.
Jeff, do your devices all support 32-bit, and do you have 32-bit drivers for all? And do you have your old SSD wiped and available (or a wiped HDD) that you could try using the 32-bit version of Windows 7? If "yes", and you would like to try the 32-bit version I'll be happy to burn a DVD copy and mail it to you in the Garden State (provided Gov. Christie didn't also cut mail service in the state to reduce the deficit?)
I think you mentioned that you had purchased an OEM copy, so you probably didn't get both the 32-bit and 64-bit disks? If you would like to give it a try just send me your mailing address by Private Message and I'll send it to you (FYI: your Microsoft Key will work with either version; but just one machine of course. The full "Retail" package comes with both version discs).
Cheers!
Robert.
). So the ample 'benchmark' information provided in this review is pretty much over my head. I did make note however of THESE comments from the review:
) does that totally cool new CCC thing of being able to treat multiple monitors like one big monitor. I forget what ATI calls it. I am not talking about a desktop spread out over two monitors but the O/S seeing one godawful big monitor so when you maximize a screen it doesn't maximize the window onto one screen but across two or three. It is also not that ridiculous "Crossfire" kludge of having two or three video cards with dongles interconnecting them, what idiot came up with that idea anyway? This might not mean much to a solitaire player like you, but to someone playing Portal 2 or Battlefield 3 in two-player split screen mode it would be highly desireable. Requires a recent version of CCC, Windows 7...and certain 6XXX ATI cards. Good luck!
