Originally Posted by bigoliver
@fjk61011,
I hope all goes well with your upgrade. Here are some problem that I came across and how I fixed them...
1. I found that at 720p (my tv resolution) I had boarders top, bottom, left and right this is fixed on the catalyst control centre, my digital flat panels, scaling options then move the bar to the far right.
2. The screen did not look as sharp as before the upgrade so I increased the resolution to the next setting and scaled again, if scaling is greyed out, goto.. my digital flat panels, properties and select Scale image to full panel size.
3. Colours looked washed out after the upgrade, I fixed this in CCC, my digital flat screen, pixel format and selecting RGB 4;4;4; (Full RGB)
4. The performance was a little disappointing so I used AMD Overdrive to clock the GPU, I have mine running at the max, 900Mhz for memory and 700Mhz for GPU.
Since I increased the performance I now get 5.2 for graphics and 6.3 for gaming graphics my GPU runs between 65c and 75c, highest I was able to reach with tests and running hdtv was 81c! I understand this to be ok for a passively cooled CPU
It will be interesting to hear how your upgrade goes.
@Renninga
Thanks for the driver advice, I did what you said and found the old signtel audio driver still there, so I removed all drivers restarted and started again. I did not use a wrist strap (or anything for that matter) but I did unplug the power supply lol, I guess I am lucky I didn't damage the card.
After all the tweaks I am happy with the card, I can now play BBCHD BBC1HD ITVHD fine, however, C4hd is all pixelated. I maybe need to re scan or something, will look into it.
Just wanted to share my experience with you all,
Oliver
@fjk61011,
@Renninga
Oliver
REPLY: Hello Oliver (and Francis),
Oliver, I'm glad to hear that you are finding the settings that work best for your LCD monitor; and the really nice thing about Catalyst Control Center is that if you ever really mess things up you can click/select the "defaults" button to go back to the "factory setups", and start over.
It's good that you were able to find the remnants of drivers from your old Sony/NVidia card and dispose of those. Francis, for your video card replacement it's best to remove all of those associated video and audio passthrough drivers before you begin your replacement (i.e., before you shutdown the computer. I read an article about a year ago which noted old driver remnants as one of the leading 'issues' with video/graphics card replacements, so always good to just start with a clean machine.
Interestingly enough, NVidia recommends removing its drivers and utilities in Control Panel. I haven't done it that way, but can't see any harm -- off hand -- in removing the NVidia and associated Signatel drivers/applications in Control Panel (Programs & Features) and THEN going into Device Manager and searching to see if anything remains which needs removal before shutting down and pulling the power cable to begin the cards swap-out.
A couple of tidbits came to mind when reading Oliver's post:
Tidbit a). If ever you have a glitch with the Catalyst Software Suite (driver issue, utility, access, etc.) reloading the software may not "fix" the issue. If a driver gets messed up or conflicted it tends to remain conflicted right through a reload of the software,or even an upgrade of the software.
I have found through personal experience that what works is to just uninstall everything, pop in the Sapphire CD, and start fresh. Remove all of the associated drivers in Device Manager -- same process as noted before; ): "Display Adapters": ATI Radeon HD 4300/4500 Series; "Sound, video and game controllers": AMD High Definition Audio Device
remember to select "Show hidden devices" from the drop-down menu under "view" to be sure to uninstall the drivers which begin with AMD and ATi prefix.
Then start fresh with the CD software suite which came with the card. After all is restored to a fresh install state, then go to the AMD site and download a fresh copy of the most current Catalyst Software Suite for your card series, and your version of Windows, and make the upgrade.
Tidbit b). Oliver, I have suffered some of the same scaling and image issues you described in your post, on my own 720p LCD HDTV. What I have found works by far the best for my LCD is selecting the "Native Resolution" of the LCD in "Basic" mode, rather than selecting 720p" which forces a non-native line resolution setup. I got a much clearer, brighter, deeper colors display in "Basic" native resolution that I was able to achieve for 720p, no matter how much I tweaked the settings.
To give that a try, if you wish, first look at the literature/specs for your LCD to re-confirm the native resolution for your monitor (e.g., mine is 1360 x 768).
Then open Catalyst Control Center, select "Desktop Management > Desktop Properties > then scroll to the "Basic" option (rather than "HDTV") and select your native resolution as recommended for your LCD model.
For my set the appearance differences are greatly improved using the Sapphire "defaults" and native resolution settings rather than forcing 720p. I don't have a clue WHY this is the case, but hey, whatever works!
If you want to give it a try to see if you get similar display quality improvements, I suggest starting with the Sapphire card "defaults" setting and then set for your LCD's native resolution. It's the only resolution setting I use now, for all viewing scenarios, and I haven't messed with 720p or 1080i in months.
Cheers!
Robert.
