Originally Posted by techieg
ChrisL01, the Anodized Heatsink form factor is pretty new because I remember a year or two ago when I was looking at Niveus they did not have the heatsink chassis then. And if you noticed in my last post I mentioned that several of the smaller OEMs use the same new heatsink chassis as I mentioned to have seen with other HTPC OEMs. None of them makes their own case or has the patent to the heatsnk case which makes it open to any and all OEMs by the manufacturers and they all have the same pool of manufacturers of any HTPC case they have the need for, so if S1Digital has the need to use the heatsink case they just have to get it from the same pool of heatsink case nanufacturers as Niveus or any other OEM who uses it.
Hey Techieg,
(I need to search for S1Digital more often - keep missing these posts). Hope you don't mind if I chime in...
We use both off the shelf and customized chassis. The Platinum Edition is based on the Silverstone LC16 chassis and we use it because it's one of the best chassis on the market. Holds lots of drives, is cool and is extremely quiet. Our FX Edition uses a case that is custom made by a vendor in Europe that we buy direct and I believe that no one else in the US offers. And our Server Edition chassis is based on the iStarUSA server cases, but we get customzied to meet our particular needs. Stay tuned for some totally custom stuff we'll be coming out with though.
Niveus use a totally custom case that they designed and you cannot purchase elsewhere.
On another note, you mentioned that you can't do 1080p under Vista Home Premium. What makes you believe that to be the case? We have our systems running 1080p under Home Premium out of the box. No hacks, reg edits, or anything else required.
Paul
- I have upgraded to Ultimate twice and both times I still needed to make the registry change to get 1080p support.
