[quote=lorne317]I've got the 360 add-on and DVE HD with the update.My problem is I can't get back to the main menu at the start of the disc.All I get when I pop the disc in is the audio/video tests menu.I can play all of the tests but there's no tutorial on how to make adjustments.Any ideas?[/QUOTE
You can use the back button or the DVD Menu button on the xbox remote to take you to the audio/video tests menu. Let me know if this does not work.
In regards to the tutorial, there is text next to each pattern for explanation, and if you are new to DVE, you can download the following doc for a more complete reference and tutorial.
http://www.videoessentials.com/dvehd...gram_final.pdf
You can also go back to the SD version on the other side of the disc as well.
