So I finally got my x-sub today, hooked it up, went through audio setup via the YPAO function on my Yamaha 2600, etc... and started putting the system through its paces.
Since then, I keep running into times (more often than not) when the sub is going into standby mode... either not coming out of standby when I power up my system or going into standby during use. Does anyone have any similar experiences or recommendations?
I am certain that the connection is fine, as it went through calibration without incident, and it has worked at times... it just doesn't seem to be getting a consistent signal for some reason - or it doesn't recognize the signal it's getting.
Help would be appreciated...
