Well i ditched Mythdora and now I am running Ubuntu 7.04 latest - I installed Mythtv front and backend - I am typing this on that computer.
I have setup Mythtv etc - it's found the guides and and and my card etc - and MYSQL.
But when i run mythfrontend from the terminal i get the following messages - it looks like my username or password are not configured to the - MYQSLSERVER
See the Log from the terminal
SELECT NULL;
No error type from QSqlError? Strange...
2007-04-21 14:43:05.851 Database not open while trying to load setting: GuiResolution
2007-04-21 14:43:05.852 Unable to connect to database!
2007-04-21 14:43:05.852 Driver error was [1/1045]:
QMYSQL3: Unable to connect
Database error was:
Access denied for user 'jay'@'localhost' (using password: YES)
QSqlQuery::exec: database not open
2007-04-21 14:43:05.907 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:05.959 Database not open while trying to load setting: GuiWidth
2007-04-21 14:43:05.960 Unable to connect to database!
2007-04-21 14:43:05.961 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:06.015 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:06.067 Database not open while trying to load setting: GuiHeight
2007-04-21 14:43:06.093 Unable to connect to database!
2007-04-21 14:43:06.093 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:06.147 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:06.199 Database not open while trying to load setting: MenuTheme
2007-04-21 14:43:06.200 Unable to connect to database!
2007-04-21 14:43:06.201 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:06.271 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:06.323 Database not open while trying to load setting: QtFontBig
2007-04-21 14:43:06.324 Unable to connect to database!
2007-04-21 14:43:06.325 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:06.379 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:06.431 Database not open while trying to load setting: QtFontMedium
2007-04-21 14:43:06.432 Unable to connect to database!
2007-04-21 14:43:06.433 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:06.487 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:06.539 Database not open while trying to load setting: QtFontSmall
2007-04-21 14:43:06.601 Unable to connect to database!
2007-04-21 14:43:06.601 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:06.655 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:06.707 Database not open while trying to load setting: ThemePainter
2007-04-21 14:43:06.708 Using the Qt painter
2007-04-21 14:43:06.709 Unable to connect to database!
2007-04-21 14:43:06.709 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:06.763 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:06.815 Database not open while trying to load setting: HideMouseCursor
2007-04-21 14:43:06.816 Unable to connect to database!
2007-04-21 14:43:06.817 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:06.871 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:06.923 Database not open while trying to load setting: RunFrontendInWindow
2007-04-21 14:43:08.029 Unable to connect to database!
2007-04-21 14:43:08.029 Driver error was [1/1045]:
Database error was:
mythtv: could not connect to socket
mythtv: No such file or directory
lirc_init failed for mythtv, see preceding messages
2007-04-21 14:43:08.031 Joystick disabled.
2007-04-21 14:43:08.092 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:08.155 Unable to connect to database!
2007-04-21 14:43:08.156 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:08.223 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:08.276 Unable to connect to database!
2007-04-21 14:43:08.276 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:08.331 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:08.384 Unable to connect to database!
2007-04-21 14:43:08.384 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:08.439 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:08.492 Unable to connect to database!
2007-04-21 14:43:08.492 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:08.547 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:08.600 Unable to connect to database!
2007-04-21 14:43:08.601 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:08.655 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:08.708 Unable to connect to database!
2007-04-21 14:43:08.708 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:08.763 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:08.816 Unable to connect to database!
2007-04-21 14:43:08.816 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:08.871 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:08.924 Unable to connect to database!
2007-04-21 14:43:08.924 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:08.979 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:09.032 Unable to connect to database!
2007-04-21 14:43:09.032 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:09.087 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:09.140 Unable to connect to database!
2007-04-21 14:43:09.140 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:09.195 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:09.248 Unable to connect to database!
2007-04-21 14:43:09.248 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:09.303 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:09.356 Unable to connect to database!
2007-04-21 14:43:09.356 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:09.411 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:09.464 Unable to connect to database!
2007-04-21 14:43:09.464 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:09.520 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:09.572 Unable to connect to database!
2007-04-21 14:43:09.572 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:09.627 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:09.680 Unable to connect to database!
2007-04-21 14:43:09.680 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:09.735 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:09.788 Unable to connect to database!
2007-04-21 14:43:09.788 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:09.843 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:09.897 Unable to connect to database!
2007-04-21 14:43:09.897 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:09.951 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:10.004 Unable to connect to database!
2007-04-21 14:43:10.004 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:10.059 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:10.112 Unable to connect to database!
2007-04-21 14:43:10.112 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:10.167 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:10.220 Unable to connect to database!
2007-04-21 14:43:10.221 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:10.275 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:10.328 Unable to connect to database!
2007-04-21 14:43:10.328 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:10.383 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:10.436 Unable to connect to database!
2007-04-21 14:43:10.436 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:10.491 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:10.544 Unable to connect to database!
2007-04-21 14:43:10.544 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:10.599 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:10.653 Unable to connect to database!
2007-04-21 14:43:10.653 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:10.707 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:10.759 Database not open while trying to load setting: Language
2007-04-21 14:43:12.339 Unable to connect to database!
2007-04-21 14:43:12.340 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:12.395 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:12.447 Database not open while trying to save setting: Language
2007-04-21 14:43:12.448 Unable to connect to database!
2007-04-21 14:43:12.449 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:12.503 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:12.555 Database not open while trying to load setting: Language
2007-04-21 14:43:12.558 Unable to connect to database!
2007-04-21 14:43:12.558 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:12.611 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:12.663 Database not open while trying to save setting: Language
2007-04-21 14:43:12.665 Unable to connect to database!
2007-04-21 14:43:12.665 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:12.719 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:17.043 Unable to connect to database!
2007-04-21 14:43:17.044 Driver error was [1/1045]:
Database error was:
2007-04-21 14:43:17.111 DB Error (KickDatabase):
Query was:
SELECT NULL;
2007-04-21 14:43:17.163 Failed to init MythContext, exiting.
jay@jay-desktop:~$
Originally Posted by
newlinux
You know, mythdora may output mythfrontend logs somewhere else so running it from terminal to see output may be unecessary. unfortunately, I am not familiar with mythdora so I don't know where it would log frontend output. I use ubuntu, and always run mythfrontend from terminal. When I first installed I had problems here and there, and looking at the output helped. That and the mythbackend logs, which if you get a terminal we'll look at next...
