AVS › AVS Forum › Display Devices › Screens › Color accuracy, which screen type is the best?
post #1 of 4
I am in the market for a new screen, gain is not an issue due to a fully light-controlled room with a black ceiling and very dark blue walls and graphite colored carpet. I am using a DLP projector that is a light-cannon, so blacks are very good, even with my HP screen that I currently use. I've done a search to find some info on color accuracy but did not find any threads about screen type and color accuracy, is there a relation?
Thanks for all comments.
post #2 of 4
Why do you need/want a new screen? What don't you like about your HP screen?
post #3 of 4
My pull-down "b" model was a temporary solution and want a fixed model. After using the HP model, the extra gain is not needed in my situation. Color accuracy is what I am after now with a NO wrinkle fixed screen(it is a dedicated room).
Jim
post #4 of 4
The HP looked pretty good for color to me. The gray screens all added a blue tint. If you want the best, then the gold standard would still be a Stewart StudioTek 130. Though personally I would stay with the high power material unless you have a few thousand to throw at a screen.
PS: You can cut the HP material off the roller.
  Back to Forum: Screens
