AVS › AVS Forum › A/V Control & Automation › Remote Control Area › URC MX 3000 Software Update
URC MX 3000 Software Update - Page 6
post #151 of 155
Originally Posted by ftbinc View Post
It is very clear to me by reading this forum that IT WILL BE VERY HARD TO ACQUIRE THE NECESSARY SOFTWARE TO MAKE THE REMOTE WORK. I WILL NEVER PURCHASE ANOTHER PRODUCT FROM THIS COMPANY - EVER. AND WILL TELL EVERYONE I KNOW THE SAME. HARDWARE W/O SOFTWARE IS USELESS.
You are supposed to buy their products from a dealer, not the company. Pretty simple really. If you don't do that then make sure you have the software lined up prior to buying the hardware.
You might want to contact support from your computer manufacturer. It appears that your caps lock key is broken.
post #152 of 155
Just purchased 9 MX-3000 remotes. Need the MX-3000 Editor software to program them. Anyone have it that can PM me with the software or link?
post #153 of 155
http://jbmaudio.net/DownLoads/Universal%20Remote%20Control%20Software/
post #154 of 155
The downloads on that site were all for various remotes that I don't have. I just purchased an MX-1200 (to replace my constantly failing Harmony 900s) - would any of those programs work for the 1200, or do I need the base CCP software?
(I will probably call URC on Monday to check about getting the CCP software directly from them, but any help for a pointer on how I could get it over the weekend would be appreciated...)
post #155 of 155
I have an MX-880 and would be super greatful if you would also PM me the CCP Software. I'm pretty much SOL without it. My dealer is out of business.
  Back to Forum: Remote Control Area
