My favorite notion is still an array up front and absorption at the back. That will work in 'open' rooms as well as sealed cubes. As the frequency goes down below the first room mode, the absorption becomes less effective, and the room gets pressurized as it should, with no fancy electronics. Two feet of fiberglass would probably do a pretty good job in most rooms. More would be better yet of course. Quoting Terry Montlick:
It's hard to measure accurately at low frequencies, but we've done a lot of modelling down there using transfer matrix methods. A two foot thickness of fiberglass batt should give you a diffuse absorption coefficient of about 0.76 at 50 Hz. With a one foot thickness, this drops to about 0.47 at 50 Hz. Denser fiberglass performs substantially worse at these thicknesses.
- Terry
_________________
ALPHA CERTIFICATION
The Home Theater Acoustical Standard
Demand Nothing Less
Terry Montlick Laboratories LLC
www.tmlaboratories.com
- Terry
_________________
ALPHA CERTIFICATION
Demand Nothing Less
. I suppose it depend on how bad his room dimensions are and what his priorities are. If it is deep, effortless, clean sound, then nothing but an IB will do. If it's a good even response across the room for multiple seating locations, then a DBA of LLT subs would probably be better. Only he can will have the answer.
