I just installed a Draper Premier Tab Tension screen and noticed that the dowel (I think that is what Draper calls the counter weight) isn't centered on the screen. I have maybe 3 inches of dowel sticking out on the left side and about 1 inch on the right side. The screen seems to operate just fine but I would like to get this centered.
Is there a way to center this dowel on the screen?
I took a look at the manual for the screen and it does talk about adjusting the tab tensioning system (screw on the end of the dowel) but I think this is dealing with how tight the tension string is instead of moving the dowel side to side.
Any help or advice is greatly appreciated.
Chris
Chris
