I'm about to do a new MCE machine around a Silverstone LC19 case. To facilitate it's 1U stature I want to use one of the new Hdmi mother boards. My problem really is with capture cards though, since this case only has a single expansion slot.
Currently I have a pair of Hauppage PVR-150MCE's, I had planned on keeping one and using in the new system, but of the three boards I like: Abit Fatal1ty F-I90HD, Abit IL-90mv and MSI K9AGM2-FIH; the Abit F-i90HD is the one I like the best. The problem is the Silverstone case requires that you use the #1, #2 or #3 PCI slots for your expansion cards. My PVR150 is standard PCI, and on the Fatal1ty board the single PCI slot is in position #4, thus won't work. My second choice is the MSI, due to cost restrictions, but am still undecided.
The issue though with capture cards, is whether I should go with what I have or look at a PCI-Express card. In my search, I have found a couple, but am curious what suggestions others have regarding a PCI-E capture card (single is all I need). I want to capture over SVHS and L/R audio from a Directv receiver. Also, I'm curious as to anyone's thoughts on or my motherboard choices.
