AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Just to show my theater (big pictures)
post #1 of 82
this is my theater finished build June ..
looking forward for a name to the theater too !! thanks
dvd rack at first
dvd rack few days later
** posters already hang
old Win. XP MCE
old Win. Vista MCE
new Vista Media Center DVD library
new 4-30-2009
XBMC Media Center (Aeon)
My Setup
B&W 603 S3 series x4
subwoofer Velodyne 1210
B&W center channel (coming soon)
Sanyo Z3
100" fixed screen (home made)
Xbox 360 with HD-DVD player
Wii
PlayStation 3
HTPC (need upgrade to get rid of the PS3 )
DishNetwork
CableTV
Sony Receiver (waiting for new receivers with hd sound, Yamaha 3800 or 1800 coming soon )
Pronto 3500 (tired of, will change for another remote more Ergonomic and maybe simpler)
Lutron spacer with IR
battery backup
post #2 of 82
for whatever reason, I love this. Are those leather covered walls or just dark paint/stain?? have anymore pictures??
post #3 of 82
Yeah, I agree. There's something seriously good about this little space. Looks comfy, complete and perfect for movies with a few friends.
The walls certainly look different with the lights on or off. They look tan coloured with light.
Well done !
Tom.
post #4 of 82
What are you using for your jukebox software?
post #5 of 82
Looks nice. I don't see a subwoofer...
post #6 of 82
Amazing work in such a small space. Very nice job!
Looks like Windows Media Center 2005.
post #7 of 82
Looks great to me. A name? How about "Orange-You-Here-For Home Theater"?
Have you ever wished your front side speakers were 5 inches shorter or that you could mount your screen 5 inches higher?
I think small, cozy, well dressed spaces like this create a very special world for movie watching.
post #8 of 82
-I use media center 2005
-walls are just paint with matte paint
- the subwoofer is behind the couch in the corner (forget to write it in the setup its a velodyne 12")
post #9 of 82
thanks for all your comments still need a good name and any suggestion is welcome ..
have a tons of pictures , what you want to see ??
post #10 of 82
the walls are concrete the roof is the same color as the walls
-the effect is exactly what i was looking for with lights on 100% looks very bright the pictures looks orange its because of the camera filter , and with lights off you can see anything completly dark no bounce light at all.
- the screen its a MDF panel paint with Behr silverscreen paint, get the advice from the forums
by the way this is an apartment .
post #11 of 82
Your set up looks great. I want to turn my master bedroom into my home theater - it's about the same size as your theater room, maybe a little bigger. Anyhow, please excuse my ignorance as I'm new to the board, but what type of projector are you using?
post #12 of 82
first post
post #13 of 82
Sanyo Z3 lcd 720p
post #14 of 82
Hi Reaven your room looks awesome. Very similar to mine actually. Did you add any extra ventilation for your projector?? I am building that part of my room right now.
And I think after looking at yours I may need to put some little soffet lights in..it looks awesome on yours.
Ryan
post #15 of 82
Ryan
am using 2 computer like fans 60mm fans, for my projector model 1 fan in the back for intake and one on the side for exhaust . i was going to built a thermostat sensor but drop the idea when found hard time looking for the components. my fans are running 24/7. almost a year in june without problems.
it runs so cool that when turn it off the internal fans keep running like few seconds only..
post #16 of 82
hey NeoOiler what you use to make your design drawing , sketch it ?? i use visio but i like the perspective look what you use ?
post #17 of 82
I used Sketchup for the first few, then Autocad for the rest. I do autocad as a profession so I am more comfortable with it.
Ryan
post #18 of 82
i was thinking about raised my rears speakers over the couch back and a little further from it??
post #19 of 82
yes you want those rear speakers higher.
post #20 of 82
For your opening in the soffet, did you just use drywall for the bottom or plywood??
Ryan
post #21 of 82
Ryan
drywall !
i know but what can I do make a complete raiser or just two boxes for the speakers ?
post #22 of 82
Great job on the room, I know pictures sometimes come out darker than seeing it in real life but It seems to have a great atmosphere. Two thumbs up.
post #23 of 82
very cool, I hope to achieve a similiar effect in my small space (smaller screen for one) but great space and I love the colors.
post #24 of 82
whats a good way to rise the rear speaker ??
need options, make a wood box individually or a big raiser in the back of the couch ?
post #25 of 82
just boxes i would think... if you build a riser for the couch, then your speakers are still the same level as they were before (relatively)
post #26 of 82
the problem i was thinking is that the floor already have a rug if i build a simple wood box i dont think it will sit flat on the floor dont know if you know what i mean , i have to in someway make the box to have some weight beside the speaker because if not the speaker will fall from the box.
i hate sand its a mess so fill the box with sand is not an option.
so......?
post #27 of 82
Nice setup reaven!
post #28 of 82
Originally Posted by cnickersonjr View Post
Nice setup reaven!
Thanks man !!
post #29 of 82
so......?
Screw the box to the wall. shouldn't take many to keep it rigid enough to keep it from falling.
post #30 of 82
Looks great!
