I have a Sony Dolby Digital/DTS Rcvr 110 watts by 5 and JBL speakers for 5.1 sound. My question is in regards to the speaker size setting on my Rcvr. I have read to get the best surround sound to work with your Sub, you should set all the speakers to the small setting. However in the manual it states to try Large first. Also, my front speakers are not really small in size--they are three way with a 8 inch woofer on both--Also, should I set the crossover frequency on the Sub Woofer up high to I believe the max on it is 170. I have a JBL 12 inch woofer--120 watt sub. Also I have a question about a button on the back of the Sub for a Phase setting? I think it has choices of 0 or 180. Can anyone explain what this does? I think my system sounds excellent now, but I want to make sure it is set up properly for the best possible sound. Thanks
[This message has been edited by chi_guy_44 (edited 01-03-2001).]
