Title says it all. I'm thinking of buying EI but only if I can get some Phillies home team feeds. Any imput from EI subs would be greatly welcomed. Thanks
Yes for the first time this year the Philadelphia and San Diego broadcasts are available on MLB-EI.
It s not guaranteed you'll get the Philadelphia broadcast, though. Generally, although by all means not always, the home team broadcast is provided to MLB EI.
There have been no Phillies or Padres home-team broadcasts from iNDemand this season. And none are scheduled, according to iNDemand's schedule appearing on their website (which goes through May). So if you're going with cable, the answer is: no.
Yea, CSN Philly feeds are usually never shown on Sportscenter, EI, etc. It's always the away team's feed. Not sure if this is a technical limitation or that CSN doesn't distribute their broadcasts.
If you subscribe to MLB.TV, you'd get essentially all the Phillies home games being broadcast by the Phillies broadcasters. By the way, you can throw the BJ's (Toronto) into the mix, since their local feeds never show up on MLB EI either.
