AVS › AVS Forum › Other Areas of Interest › Camcorders › First time camcorder owner, tips needed
post #1 of 2
Greetings everyone!
In just two days i will be a VERY proud owner of HV20, and since i've never owned a camcorder before, i'd like to get some tips from you on what should i also buy with it and what should i do before actually shooting etc. The thing is, i live in a small town that doesn't have any decent camcorder supplies shops and getting anything extra requires travelling, so i'd like to avoid that if possible. For instance, i read on other forums that before actually shooting i should definitely use a cleaning tape. Is this true or not?
I'm not exactly sure what to ask, since i'm competely new to this, but i just want to know is there anything else besides camera and tapes that i should buy? You know, bits and pieces that are necessary in everyday life. I plan on using the camera very often. I will be buying a backpack for it when i get the cash. Anything else? Also, any first time usage tips would be welcome.
Thanx.
post #2 of 2
Ooops, i just saw a similar thread
Can any of the oderators merge this with " Ordered HV20, now what do I need?" topic?
  Back to Forum: Camcorders
