Are they really that much diffrenent between the two?
Ive heard they were almost two diffrent worlds between the two speakers. Havnt gotten a chance to listen to the 805s because nobody has them in stock around here just the 803s.
I also heard the 805s were very power hungry and inefficient, What do you say would be the needed wattage to power them.
Would a 130/140watt per channel reciever do it or is this way too low?
Also how do the 800 series speakers match up with the 700 series speakers?
805/HTM7 for instance?
Emil,
Emil,
