Andy,
THX EX calls for 2 rear speakers. When you configure speakers in Lexicon set-up, you have a choice of rear speakers or none. THX is pretty exacting, so you do not get the same flexibility choices in set-up. I suppose you could only hook one speaker in the rear and choose left or right for its set-up. However, I would suspect that the intended effects will not be produced accurately--you calibrate configuration volume initially for reference. "Tricking" the system for using only one speaker may mean reduced db in the rear. I would not recommend it. One of Lexicon's true strengths are the various 7-channel effects. If you are considering Lexicon and want rear as well as side channels, 2 not 1 rear speakers are needed.
There is a minor glitch in the EX processing regarding volume for rears and sides. There are a couple easy workarounds suggested by Lexicon. Suggest you check out the SMR forum for Lexicon. This is an excellent source of information. The forum is now located at
http://discussion.iland.com/~smr-forums/login. Check out posting on 12-13-00 on suggestions for EX workaround.
Will
[This message has been edited by Will Gibbons (edited 01-06-2001).]
