Originally Posted by
Don_Kellogg
Ruben do you have a date for the masking system yet?
Hi Don,
We are now shipping:
Four way native 1.78 flat masking systems. This system allows you to do unlimited aspect ratios without being constrained to constant image height or width.
Two way native 2.40:1 curved and flat constant image height masking systems. These systems mask down from 2.40 to 2.37, 2.35, 1.85, 1.78 (16:9) and 1.33 (4:3) and anything in between.
Two way native 1.78 flat constant image width masking systems which can accommodate all your constant width aspect ratios.
Two way native 4:3 flat constant image width masking systems which can accommodate all your constant width aspect ratios.
Each ProMask masking panel is independently controlled so you can adjust for off centered projected images or independently drop down the bottom mask for subtitles.
The ProMask masking systems are hand built to the highest quality. We hand pick the quietest motors and bench test all the parts before assembly. Our motors are about 20% - 30% faster than the motors in most of the masking systems currently on the market. We use structurally engineered extruded rollers to assure no waves for life in the masking panels.
We acoustically insulate the frame and rollers and use other acoustical methods which makes the ProMask the quietest masking system on the market. If you ever had a chance to hear how loud and bulky some of the other masking systems are on the market, you'll appreciate the methods we use.
The diameter of the ProMask frame measures 4" wide x 4" deep and comes hand upholstered with our true black hole velvet. The ProMask can be aperture mounted into a regular studded wall or hung on the face of a wall. There are 3 frame face profiles to choose from to meet everyones style. We can also do exotic wood veneer frames and various velvet colors if requested.
The ProMask accepts a lace and grommet screen, so any screen material can be used with them. The ProMask seamlessly integrates into any automation system such as Crestron, Amx, etc. and is controllable by IR, RF, IP & Dry Contact.
For audio transparent screens such as the CineWeave, we also have audio transparent masks.
The ProMask can ship fully assembled or partially assembled.
Standard sizes up to 24' wide, larger sizes can be accommodated.
Ruben
