AVS › AVS Forum › Display Devices › Screens › ***Official SmX Theater Solutions Screen Thread
***Official SmX Theater Solutions Screen Thread - Page 20
post #571 of 1209
Originally Posted by SandmanX View Post
Hi Jacob,
I don't think a curved screen is necessary for your set-up. You will most likely be fine with a flat screen and a little bit of over-scanning.
Ruben
Hi Ruben,
Is that due to the (long?) throw range or due to the wide seating arrangement?
Will the wide seat arrangement make a curved screen a BAD solution?
I did read the linked description of the curved SMX by the way.
Jacob
post #572 of 1209
Originally Posted by Jacob B View Post
Hi Ruben,
Jacob
Hi Jacob,
That is due to the throw distance. At that throw distance and depending on the lens, you will most likely still have some distortion to deal with. It should be minimal and you should be able to overscan your projected image to let it bleed off the flat screen surface.
As far as your seating arrangement, it sounds similar to mine and we have no problems using a curved screen with ours. The CineWeave screen surface is completely uniform and there is no issues with viewing cones or hot-spotting. Every seat in the room will experience the same incredible image.
Best
Ruben
post #573 of 1209
Hi Jacob,
Best
Ruben
Does your smxscreen@gmail.com email work? Or do you use another email?
I send you an email last week to this address.
As for the curve, my worries are whether the outer seats won't be looking at a screen where the curve increases the viewing angle at the closest side of the screen (while decreasing it at the farthest side) - and hereby decreasing the viewing experience? The outer seats will be at the ends of the screen.
Jacob
post #574 of 1209
good question Jacob.
post #575 of 1209
Jacob
As Ruben already advised you, you probably are better off with a flat screen. Truthfully, in the size space that most of us have, I don't believe a curved screen really offers much of an advantage - other than cool factor. But, I'll caveat that with the fact that I don't have a curved screen and have never even seen one in a space smaller than a commercial theater. So, that is purely ignorant conjecture on my part.
post #576 of 1209
Jacob
Hi Jacob,
I responded to your email last week maybe my mail is in your spam folder?
A standard curved screen does not have that dramatic of a radius. What you are asking about isn't an issue with standard curved screens. Now if it was a 10' radius or something real dramatic then that would be a good question.
The reality is, even if you went with a curved screen, it would be such a subtle radius that it would not change your viewing experience any more than a flat screen.
Ruben
post #577 of 1209
Hi Jacob,
Ruben
Hi Ruben,
I fear you mail has ended the same place as those advertising for longer and harder organs
Please resend if possible,
Best regards,
Jacob
post #578 of 1209
Hi Ruben,
Best regards,
Jacob
Hi Jacob,
I responded to your email, hopefully you got it this time.
If not, please PM me.
Ruben
post #579 of 1209
Hi Ruben (or anyone else),
For some reason your phone is not working. We are about to open the crate for the CH screen and want to make sure the screen is properly positioned (depth) from the stage. Can you tell me the depth of the brackets that attach to the wall? I know the screen depth in the literature says 3.25", but I am pretty sure that doesn't include the bracket. Thanks in advance for a timely response.
post #580 of 1209
Ruben,
Back in April you mention you "may" be working on a high gain SMX screen. Any update?
post #581 of 1209
Hi,
Our phone lines were down this morning due to severe lightning. They are back up now if you want to call in again. You can also send me a PM or email with your email address and I can get you a digital installation manual right away. There is a manual inside the crate as well.
Ruben
post #582 of 1209
An incredible theater by Artie with a 130" wide 2.35 ProCurv. His theater build is going to be featured on on HGTV "New Spaces" this Saturday 9/20 @ 8:30 AM EST, Check it out!
"Ruben,
Long time no talk to. Finally done with the HT build out!!! Everything looks & sounds great.
I'm real happy with my 130" SMX ProCurv !!!!! You can count me as a "satisfied customer."
Check it out this Saturday 9/20 @ 8:30 AM on HGTV "New Spaces."
post #583 of 1209
Wow- very nice!
CJ
post #584 of 1209
Any word on the new screen fabric?
post #585 of 1209
Originally Posted by JeffinChelsea View Post
Ruben,
Hi Jeff and ksharp4,
We should have some updates this week about our new high gain woven AT screens, please check back in here throughout the week.
Best
Ruben
post #586 of 1209
Truly a nice theater room, that screen looks awesome.
post #587 of 1209
Best
Ruben
Anxiously waiting...
post #588 of 1209
They are still in the lab testing, hopefully we receive some updates shortly. Anxiously waiting too...
Ruben
post #589 of 1209
Ruben
Thanks for the info. I was hoping to purchase an SMX screen and receive it by mid November. Can you at least tell me if it is possible whether this might be available by then? Would be happy to be a tester!
post #590 of 1209
Best
Ruben
Would you consider offering this new high gain material to DIY'ers for a limited time like you did with your current SMX material?
post #591 of 1209
+1! I have a 10' wide 16:9 SMX that has no border. It hangs in space so the image floats in the dark. It's very cool and I'd like to do it with the new 2.0 gain material.
post #592 of 1209
Sweet! That would open up a whole world of possibilities
post #593 of 1209
Ruben,
I was wondering if you ship to Australia? I am after a ProCurv 130" (Viewable Width) screen with Non-Cineweave material as my speakers are not suitable for mounting behind a screen.
Kind regards
Justin
post #594 of 1209
Oh, and any chance of just selling the material?
post #595 of 1209
Hi Ruben, I sent you an email.
post #596 of 1209
bump.
Where is the 2.0 gain material? Not here yet ....
post #597 of 1209
Originally Posted by kevivoe View Post
bump.
We got the labs back this week and the formula still needs work. I thought we were there and we weren't. The next post based on these new materials will be once they are available.
Best,
Ruben
post #598 of 1209
Most likely not at this point (see post above).
Best,
Ruben
post #599 of 1209
Originally Posted by BladeRnR View Post
Ruben,
Kind regards
Justin
Hi Justin,
Yes we do, we ship all over the world.
Best,
Ruben
post #600 of 1209
Hi Ruben,
I'm configuring a home theater room with dimensions of 13' x 15' with a 9.5' ceiling height at the wall (it slopes up from there in a "V"). From what I've read in this thread, your horizontal masking system requires an addition 5.5" (per side). For a 100" wide screen, will the total width of the screen, frame, and mask be 100+2*5.5=111"? If so, that would leave me 22.5" on each side for my speakers which are 18" wide.
Current eye position is 14'. With a 2.35:1 screen, the height will be 42.6", so the minimum seating distance is ~7.1'.
I plan on using a 16:9 projector with a Panamorph UH480 (with MTH1 Sled). Will a Panasonic AE3000 projector or a JVC RS20 projector work for this configuration?
Finally, could you PM me a price for your 100" 2.35:1 SmX screen (curved AND flat) with horizontal masking?
Thank you!
  Back to Forum: Screens
