AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Best Paint-On Screen for Bat Cave with DT-500
post #1 of 18
I've been reading & reading, but am getting lost & confused. I think I know what I'm looking for but not sure what paint-on DIY method is going to give me what I want.
I had used the MM for my latest screen using a dim LT150 which gave a really good picture, but I just recently bought a Sharp DT-500 and that thing is BRIGHT! My theater area is dark and the projector is so bright it hurts my eyes even with the iris engaged and on econo mode.
I'd like to have a Grey Screen to enhance the blacks even more and hopefully tame some of the brightness, however I *think* I would like to have some gain so that when I show sporting events with ambient light, the screen isn't too washed out or too dim. I'd like to not have to change the brightness setting or iris of the projector if at all possible. Suggestions?
- When I last did the MM paint, I don't think I added enough Silver Metallic to the mix because my screen doesn't have much grayness to it.
post #2 of 18
Both CMRA and I can attest that for the 500, a S-I-L-V-E-R application is wonderful. That is the PJ he is using, and the Knave dares to say it outperforms his own Light Fusion Screen, one he steadfastly stated to all was better than a StudioTek 130
But the S-I-L-V-E-R will certainly ZAP your eyeballs if they are overly sensitive. It does not seem to bother CMRA, or any of the people on my end, because it does not Hot Spot or "glare", but bright it most certainly is. But that just adds more Contrast since the Silver element greatly increases the Black levels while bringing out detail seldom seen under bright or Dark circumstances. IT'S THE DIFFERENCE BETWEEN THE LIGHTEST AREAS ON SCREEN AND THE DARKEST AREAS THAT DETERMINE HOW GOOD YOUR CONTRAST IS. .....caps attack....
Another "Positive GAIN" choice is RS-MaxxMudd. That mix was the upgrade to MMud-SE, which appears to be what you have since you state you added Silver Metallic.
You one of the "MMud Family" ya know, so that means you get extra special treatment the second time around. I'm not even hurt that you doidn't ask for my advice personally.
Not much anyway.
Well maybe a little.
I'll get over it.
post #3 of 18
The Sharp is a great machine by all accounts I have read so far and I use its older brother in my media room the 10X. from the conversations I have had they are similar in brightness and my room lighting sounds much like yours and also the desire to have some good PQ on sports with the bat cave lit.
If I had to upgrade today the DT-500 would be on the top of a very short list for me.
I have viewed your construction photos before and your room looks most impressive.
You didn't mention your screen size and giving out screen paint recommendations without knowing what size you are shooting too or better yet what FL level you are at IMO would be premature.
You did mention your MM screen is blinding. And that's a good indication of how much darker you should be able to go. I believe it's a misconception that in light controlled settings even with darkened light absorbing colors and textures in a room like yours that gray is not an option. First you have a excess of lumens why cut them down with a filter or a iris in this case when you can kill some at the screen surface and punch the real black level up and also the perceived black level. While bringing the whites down where they should be. Keep in mind gray even dark gray or black will reflect a white image. Is a huge misunderstanding / (myth even) that white will only appear as the shade of gray the screen is. I have been beating this drum for a good year now
But here is the interesting part of ambient light performance to me with a bright projector. With the lights turned up you are still not going to need that gain. You have the lumens for the bright colors its CR you loose and you loose it off the dark end of the image. That gain isn't going to help you darken the blacks its going to make the ambient that's overpowering them brighter. To overstate the simplistic. Black is projecting nothing or close to it. With ambient task lighting it's about the screen not reflecting. And a slight amount of ambient absorption at the screen combined with a bright image to compare the (black) with is what boasts perceived blacks.
Factor in how your eyes change aperture with a task lit room and it's very possible to have a dual mode media room.
I have several links below in my signature that detail my ideas about this and some of my last entries in the screen paint thread even show photos of perceived black.
post #4 of 18
Not much anyway.
I'll get over it.
Perhaps.
The OP mentions his "Bat Cave", a term reserved for 'black hole' environments. The DT-500 certainly does NOT require such to achieve its 'best' image.
Without toning down the brightness, S-I-L-V-E-R may infact be 'overload', more so than he already experiences.
I should have the chance to view my 500 in Scopeboy's dedicated (bat cave)theater on his NEW screen soon so I'll have a better feel for the situation.
More later...perhaps.
post #5 of 18
Thanks for the compliments!
My screen size is 110" - (~54"x96"). The projector is 1200 lumens in Bright mode, but the manual or website does not provide for Eco & Quiet. In the specs it states that the bulb is at 355W for Bright and 310W for Eco & Quiet, so with that ratio I'm assuming it's ~1050 lumens. My last projector was an LT150 at 800 lumens. When the bulb was brand new, it was the perfect brightness. I don't have a way of taking FL measurements, but using the 'theater calculator' provided by Carlton Bale, with the LT150 it was 24.5 and with the DT-500 it is 32.2 FL.
When all of the lights are off, it is absolute darkness. You can not see your hand in front of your face. The ceiling is black and the carpet in the darker range. The walls are the weakest point of reflectivity with a tan on top and an 'olive green/grey' wainscot.
This past weekend we were watching sports with most of the lights on. I've installed lighting so that none emit light directly to the screen. Any light that reaches the screen is indirect from the walls, etc. After viewing and thinking about it more closely, the ambient light does not affect the screen all that much, so I probably shouldn't be all that concerned with it.
When I first mixed the MM with silver metallic I was hoping it would be more gray than it is. Therefore I've always been keen to a gray screen.
I read through the posts in your signatures and really like the Silver Leaf mix, but your projector is 2x the lumens. How do you feel it would apply to my environment? I'm thinking about using some of the silver metallic instead of the poly.
I'm trying to keep from having to create & test too many variations since I have very little time, wanting to devote most of it to my little girls.
CMRA,
I'm extremely interested in your bat cave tests with the 500. Please let me know!
Thanks for everyones help & input!
Neuner
post #6 of 18
Neuner
As you know my light control and room colors are quite similar to yours and it seems your image tolerates some indirect ambient light about the same way mine does.
It's true my Sharp has a higher rated lumen level but it's a 4:3 projector and we share the same screen width of 96 so when I watch 16:9 material I'm viewing the same 54x96 screen you are. The difference is 25% of my lumens go unused. Based around the wattages you posted and diminishing my eco mode lumens by 25% I think we could be very close in output. And seeing as how both projectors are Sharps my guess is they are measured in a similar manner. I know you have iris settings and it's not a business projector for whatever that's worth but the brightness you described sounds pretty similar.
I actually don't think you would be way off in trying the silver leaf shade of gray. And no one wants to spend months experimenting with this. well almost no one. Buy a quart of silver leaf for 10 bucks and paint some on a piece of a cardboard box and take a look. If its to dark you could add some white to get a feel for what a darker gray might do for you. You know my thoughts on the metallic they are great if you need them. I think you might not need them with the new DT-500 I know I don't need them with the 10X
By all means spend as much time with your girls as you can.
post #7 of 18
Thanks! With your help & suggestions I will be able to accomplish this. You are saving me a lot of time and I appreciate it.
I'm going to paint a small piece of board as you suggested and give it a whirl as soon as my projector comes back for repair.
post #8 of 18
No problem with the help see when my 10X gives up the ghost and I get a DT-500 to move up in the world maybe I'll know just what I want for a screen this way.
Give yourself a good size test panel when you make it 2'x2' min. and then view it with and without a calibration. Then keep in mind mixing a little poly in the paint or putting the flat poly over it is going to give you a nice bump in brightness without changing what you will be seeing much at all as to colors or black level.
post #9 of 18
I HAD a DT-500 (bulb blew up), and started with a flat white wall, it looked great.........
I then repainted my wall Benjamin Moore "Pebble Beach"(very similar color to SW "Grey Screen")- 2 coats, over the flat white paint.
I then added 2 coats of #780 Behr.
Results?
Outstanding for a cheap and FAST screen, IMO, much better than the flat white, especially with any light in the room.
post #10 of 18
Sharp stated that my projector should be here today or tomorrow so I went and got the paint and the poly.
The paint is Vaspar (new label for American Traditions Lowes) with 22 shots of Lamp Black. Didn't come out as grey as I thought it would. Doesn't look as dark as some screen samples I got from Draper.
Got a quart of Behr 780 Water based Poly with Matte finish. It is expensive!! Tried two stores and only one of them had it because it was a returned item.
I don't think it will take me too long to get everything done, I just have to find an opening in my busy weekend. I'm going to try and set up my Digital SLR in full manual mode and use settings that give me an ideal 0-255 histogram for taking shots of my current setup. I'll then use these same settings to take screen shots of the new setup. Hopefully the difference in contrast and brightness will come through and can be seen in the photos.
post #11 of 18
Alot has changed with the arrival of the refurb from Sharp. You can read a little about it here. There must have been something seriously wrong with the bulb to make it that bright. In Movie2 mode I still had to set the brightness setting to -27 and it was still way too bright. The refurb model has a wonderful picture and changes everything. I took pics of the 500 with my MM +SM screen but left them at home. Hopefully I can post them tonight or tomorrow to show the difference.
post #12 of 18
All's well that ends well.
Looking forward to seeing the pictures.
Did you ever do the gray sample for comparison?
post #13 of 18
No, I want to paint a new screen anyway, so I'm just going to paint it gray anyways. I have MM +SM left over so it won't take much to re-paint it if I don't like it which is doubtful.
post #14 of 18
If you could do us future DT-500 owners a favor and still do a sample first and take a couple pictures of the neutral gray compared to the MM+SM you have now as a side by side. It would be greatly appreciated.
Plus that will give you the chance to adjust the gray one way or the other based on what you see and like.
post #15 of 18
I'm comparing the images of the DT-500 versus the LT-150 projectors and to show my results with using the MississippiMud +SilverMetallic.
I only have screen shots with the MM +SM screen currently. I plan on painting a new screen in thirds. I'll leave up the MM, and then have a neutral gray in the middle and then neutral gray with the poly.
I used the common HD test files of irebars, colorbars, and ramp. I also used the running video, and misc HD programming and SD DVD. I took these photos in an absolute dark room on a 110" 16:9 screen. The paint is Mississippi Mud with Silver Metallic (1:1:1). The screen wall is painted a generic flat black.
I've used the NEC LT150 projector with a (fluorescent ?) filter at 800 Lumens and ~400hrs on the bulb. It has a rating of 800:1 contrast. I'm using Powerstrip to have 1024x576 resolution. I have to use keystone due to the low ceilings.
The DT-500 has assumed 1000 Lumens set on Movie2 Mode with Econo / Iris engaged. I've seen measurements on this forum of 3000-3500:1 contrast. My unit has <10hrs on it for these screen shots. I use Powerstrip to have a 1280x720 resolution. I am not currently using keystone.
The Nikkor 24-120mm f3.5-5.6D AF lens I used for these pics has a sweet spot between 35-70mm with minimum vignetting and chromatic aberation. I set the lens at 60mm and the camera at ISO 100, f/5.6, and a shutter speed of 5 seconds. The camera was on a tripod at 5'-6".
LT150:
To show how much brighter the DT-500 is, here are screen shots with the shutter still at 5 seconds. I still need to level & align the projector, so please forgive the distortion. The projector is set to Movie2 - econo mode, iris engaged. All settings are '0'
To get an equivalent Histogram of 0-255 with the DT500 I had to adjust the shutter to 1.3 seconds. There is discoloration in the corners of the image which aren't there during normal viewing so it must be the camera adding the distortion.
post #16 of 18
For these screen shots I tried to get the same frame, but it was hard to locate without a counter guide. Hopefully these are close enough. Reminder that the photos for the LT150 are set at a shutter speed of 5 seconds and the DT500 is set at 1.3 seconds.
LT150:
DT500:
LT150:
DT500:
LT150:
DT500:
The DT500 really brings out the shadow detail like everyone described. I have since decreased the brightness to -15 to eliminate some of the washout as seen in the photos.
I will be taking future screen shots once I roughly calibrate the projector with the MM +SM screen and paint the new screen test areas.
post #17 of 18
Neuner
Screen shots look good now. Glad to see you got thru the hosting problems.
Seeing the difference in exposure times of your photos will tell you what your eyes are starting to tell you about how many more available lumens you have going at the screen now.
It's always hard to compare two projectors that require so much span in calibration.
Looking forward to seeing your side by side screen shots comparing the grays.
post #18 of 18
I hope to get to it sometime soon. I'm really busy at work and the littlest one has her third ear infection with a fever so my family is beat & tired. I need to get a ceiling mount that drops the projector a couple of inches for proper alignment. Hopefully this weekend I'll be able to do something.
  Back to Forum: DIY Screen Section
