Hey all!
I just upgraded to a new EX receiver and need a few more banana plugs so I can connect my new speakers to the receiver. The ones I use now I bought at a local high-end store. They are made by Esoteric Audio USA. I think they are called inter-loc banana plugs. You stick the wire through the hole on the bottom and then spread the wires over the top. Then you put the connector back together and the wires get sandwiched between the top and bottom pieces. Does anybody know what I am talking about and where to find these conectors? Any help would be very appreciated. Even a suggestion of another brand would be great. Thanks to all!
