Hey folks,
I have an "equipment rack" that I use outside. The proejctor simply sits on the top of this. It works ok, but I was thinking of getting it "up" higher, so folks could sit in front of it, if they wanted.
What do you think about taking a ceiling mount and using it upside down? If I installed the normal mount on the top of my "rack" and extended it up, then installed the projector on the mount, is that asking for trouble?
Thanks for your thoughts!
Here is the current rack, shelf, thingy....
