AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › HAU MediaMVP MCE Skin Mod Project 2007
post #1 of 16
Okay you just got the MediaMVP, but you don't like the look of the default GUI. A programmer from Norwich made a new interface. I've just improved it for current version HAU Beta..
Should have this ready by sometime this week.. I'll post what I've done so far when it's fixed..
post #2 of 16
Very cool! It will definitely bring the MediaMVP to a new level of refinement! Can't wait to try it out.
post #3 of 16
Good, then I am heading in the right direction I'll post the update soon. I've just finished working on the final look as show in the next post.
post #4 of 16
OSD with timeline and volume
post #5 of 16
Features
Mute On and Mute Off OSD
Main Menu with 24 hour clock
Completely re-skinned
Main with 24 hour clock
MyVideos
OSD timeline
OSD timeline and volume
Note: You need to backup your HAUMediaMVP folder if you want to save your old graphic. If not just run the installer it will do the rest.
Download media_mvp_mce.exe 646KB
post #6 of 16
Thanks Tipster!
I'm a bit unclear on what is needed to install this though. I'm currently using the MediaMVP Media Center like the one here:
http://www.mvpmc.org/index.php?pg=main
Do I have to open up the bin file to add this theme?
post #7 of 16
I found this on the FAQ:
http://www.mvpmc.org/index.php?pg=faq#q30
Does the exe automatically just put the .XML theme in the to /tmp/themes location?
post #8 of 16
Thanks Tipster!
To avoid any confusion this thread has nothing to do with mpvmc and it's support for ReplayTV or ReplayTV itself.
To avoid any more confusion it doesn't do anything to the mvpmc themes folder you are asking about.
Martin.
post #9 of 16
No this is for people who are using MediaMVP and want a different skin look and feel and some other features., I am not supporting MVPMC skin project. That's another project. I am just keeping this project started in 2005 going..
post #10 of 16
It's been tested. What that does it update the image folder and the main hau mediamvp folder with the tools needed to get the skid mods the way you see it. I don't know about MVPmc project someone else is working on that one. You really don't have to do anything except if you want to backup the mediamvp folder. Next time when I have a chance I'll great utility for you that will just do it.
post #11 of 16
I've been working on this just now, but it will be in the next release. I will include a small program that would allow you to choose which style you want, backup/restore prior or current MediaMVP Skin Mod your using. The above makes it easier to view your recordings. Use either CTPVR, GBPVR, SAGETV, BTV, to record then playback using MediaMVP MCE mode.
Style 1
Style 2
post #12 of 16
What's New!
I've re-designed and fixed the graphics this time around.
Added New Graphics and New OSD Function Buttons
Added My Videos Style1 and My Videos Style2 choices
New Main Menu
My Videos Style1 (default)
My Videos Style2
Settings
Download the file from www.putfile.com/tipstir
post #13 of 16
What's New!
Changes throughout skin mod as show above.
Gone is that table form box so now it looks color matching neat...
Fixed some color glitches in Fonts too..
Download mediamvp_setup.exe 724KB
post #14 of 16
What's New!
Re-package Setup/Installer
Fixed a problem with My VideoDisplay 1/2 when you install them from MCL
Added Un-ZIP to solve the above to MCL
Added ShortCut Installer to MCL
Added Clean Folder to MCL
Added Readme/Instructions to MCL
Download mce_mediamvp_setup.exe 2.12MB
post #15 of 16
Back again with a new refresh look still trying to have something different as you can see below this is what the skin mod now looks like:
What's New!
Latest design changes from MCE to SE
Fixed Volume Graphics in Music so it matches theme
Changed the fonts on the main and throughout the skin mod
Main Menu
Videos 1
Videos 2
Download from here:
http://hosted.filefront.com/tipstir/
post #16 of 16
http://tipstir.blogspot.com/
What's New!
Cleaned up the file structure
Changed the appearance of OSD Info for Video Playback
Readme.txt included
Note: Prior version is still available on..
  Back to Forum: ReplayTV & Showstopper PVRs
