Originally Posted by R Harkness
Thanks again (and I will check out the scaler info)....but I may well be relying on some form of zoom method, at least at first...so I'm still waiting for a reply to my original question:
When zooming the RS1, does the image zoom out equally in all directions (expands simultaneously in all directions, center of the screen staying central), or does the top or bottom of the image remain constant while the other part expands...as is the case with some projectors....and which would entail having to lens shift along with zoom with a zoom method when trying to match the top/bottom of the image to the top/bottom of the screen area.
It depends on your projector placement. I am using about 40% vertical lens shift. and 3 % h shift. When I zoom, I have to re-center on my screen. The shift controls are a little loose but it still takes less than a 30 seconds to do.
If you use zero V and H lens shift you probably wouldnt have to much if any correction.
Hope this helps.
Tony
Whats your pq like with SD DVD material?
