I waiting for a used U15 Panamorph I bought to turn up. I don't want to have it permenantly left out as it isn't a dedicated theater room, so I need to work out a way of having a quick detachable fitting for the new lens. I watch a couple of 16:9 HD TV programmes midweek on the PJ and usually watch a film or two over the weekend that typically are 2.35/2.40:1 so I'd only need to pop the lens on at the weekend.
I'm thinking slightly latterally in that I thought about making a flat plate out of MDF or similar that the PJ stands on. Then screwed to the shelf shown in my attached picture and having two drawer sides that pull forwards with a bar of MDF to allow the lens mounting bracket to fix onto, using some 'thumbscrew' type nuts to tighten it. This pull out shelf can be pushed back under the PJ when the lens is not in use. Any other suggestions gratefully received.
Slightly off topic, is anyone using a U15 with an AE2000 ( or AE1000)? I know it isn't a very high quality lens from reading up on the AVS archive forums, but I hoping it will work OK as I use a very long throw to minimise the lens area in use. I can't use a HE lens as I've calculated the image will be too wide for my screen, but if the U15 proves too soft, maybe a newer U85 might turn up in the future and this would be a striaght swop. I only paid £90 for the U15 so it's no biggy.
EDIT: I picked up a pair of heavy duty drawer slides from B&Q (UK equivalent to Home Depot I believe). They fit nicely onto the underside of the shelf, now I need the Lens for measurement purposes. I can add a small piece of Black anodised aluminum angle to the front edge which will hide the shinny ends of the slides and provide a strong surface to fix the lens bracket onto. I also bought some 'wing' nuts that I intend to use as the quick release mechanism to unscrew the lens bracket from my slide. I guess a picture will make things much clearer, so I'll post back once it is completed, incase it proves useful to someone else.
