AVS › AVS Forum › Display Devices › Screens › The official SeymourAV center stage screen thread!
The official SeymourAV center stage screen thread! - Page 56
post #1651 of 2117
Originally Posted by toref View Post
SE has a DIY product called "Craftsman" which consists of the fabric, mounting profiles, the black backing and a particular tool to attach the fabrics to the profiles.
The Craftsman product is EN4K
post #1652 of 2117
http://www.screenexcellence.com/products/craftsman.html
"The Craftsman is only for skilled installers"......
How skilled are we???
Chuck
post #1653 of 2117
Dang, and I just bought XD mateial last week. Oh well.
post #1654 of 2117
I compared both and went with the XD Material. There's no advantage to the 4K material unless you are 8ft from the screen or less. Otherwise XD holds a better image IMO. I couldn't be happier.
post #1655 of 2117
I have a question about backing to be used behind a screen. I read in another thread that if we use white backing behind AT screen, it helps with the screen gain. does that makes sense, instead of using black? I want to do approx 128" wide, 16:9 screen, so brightness is quite important for me.
Also, has anyone here used black muslin as the backing? It would be interesting to hear the experience.
If you purchase EN4k, it comes with black backing. I don't know what it does to contrast to have white or black. I have a good black background behind my screen so I didn't use the black backing (this advice has previously been given by Chris in this thread). I didn't want any extra audio attenuation. The problem is, since you cut the EN4k to only 1/4" outside the frame, if you make a decision, I guess you are stuck with it, or risk not having enough extra fabric to change your mind.
post #1656 of 2117
+1 on not using the black backing if you have a black rear wall and have spent the time to make sure everything is flat black and non-reflective back there.
I don't quite understand the rest of your statement though... please interpret. The stuck and change your mind parts...
post #1657 of 2117
This chatter about the SE Craftsman installer package is interesting, though its not clear to me whether its available directly only from SE or also thru Seymour-SE. Chris?
post #1658 of 2117
Hi Tony,
Please elaborate further on your comparison!
I will be sitting 11 to 12ft from a 120" wide (130" diagonal) Scope Screen in a totally light controlled room.
...Glenn
post #1659 of 2117
Using a white backing behind an AT screen can help with brightness, but it ruins the on-screen contrast ratio and sharpness with light contamination. Try a checkerboard pattern with and without to see the differences. Not recommended.
Anything black behind the screen will optically work. Muslin isn't very acoustically transparent, however. Perhaps cut out around the speakers so it's effectively just a removable version of a black paint job?
Chris
post #1660 of 2117
The Craftsman series isn't available in North America. In 2010, I instead reduced the pricing of the fixed frame by 20 to 50% to make it the obvious value among its retail competitors here.
Cheers,
Chris
post #1661 of 2117
Chris, can you PM me pricing for a RF 120 HD and an RF 150 WS? I want to compare pricing between the XD material and the 4K. I would not need the black backing the the 4K material as the space behind the screen will be blacked out.
I'm thinking of going with the wide screen to better future proof my purchase. I will more than likely run my screen in 16:9 and order a set of masking panels also.
post #1662 of 2117
Originally Posted by Glenn Baumann View Post
Hi Tony,
...Glenn
Which projector?
post #1663 of 2117
Hi Tony,
I don't know about Glenn, but for me it will be the Epson 5010/6010. I'm also interested in more details about your comparison.
Chuck
post #1664 of 2117
which projector?
jvc rs45
post #1665 of 2117
The image on the XD material had more pop and was more vibrant vs the E4k IMO. The 4k material did not seem to retain as much light as the XD. As for the physical material, the 4K seem to delicate and easy to snag or tear. The XD was pretty strong and closer to a tradional screen material.
I would suggest ordering a 24x24 sample of each from Chris. It's enough material to give you a good idea on what results you can expect from your projector. For me, unless I'm 8ft or less, XD all the way.
post #1666 of 2117
Thanks for the response Tony... Nothing like a real world subjective experience!
My real concern has always been the XD's weave visibility from my proposed 11 to 12 foot seating distance!
The bit of extra gain that the XD has over the 4k can certainly help and the price of the XD is much less expensive than the 4k... YIKES!
...Glenn
post #1667 of 2117
Ok, what I meant was the Screen Excellence instructions tell you to cut the material so you only leave 1/4" after you put the fabric in the frame with the spatula. If you do that, without the black backing, you are probably cutting it tighter than it would be with the black backing because instead of having 2 layers in the frame you only have one. You may not have enough left to spatula in 2 layers of fabric if you cut it using the 1 layer as a guide.
But now I am told by Chris that he doesn't recommend cutting it anyway...so its a moot point and anyone with a EN4k should consider taping the extra instead of cutting anyway!
post #1668 of 2117
I went with the EN4K for future proofing. You're absolutely correct in that XD is brighter...I believe I posted a pretty god picture of the difference a few pages back.
One of the things I did notice is that the XD was a little annoying on white scenes
post #1669 of 2117
I didn't tape or cut or anything. Just left it there... it was only about 1 or 2" all around anyway.
post #1670 of 2117
Chuck
With a clean floor and clean hands I think most amateurs would be able to install it. But naturally, SE needs to make this disclaimer because there is absolutely some risks of getting it wrong. The fabric is delicate and must be treated correspondingly.
post #1671 of 2117
My viewing distance was the main motivation for me too - in selecting the EN4K material. About 7-8 ft. I think you're absolutely right in suggesting that the viewing distance is used as the criteria. The XD has more gain as well.
post #1672 of 2117
...Glenn
No visible weaving at 11ft. I started to notice some slight weaving on white images about 9ft or so.
post #1673 of 2117
That may vary a bit with visual accuity, but overall I agree with Tony's observations in his posts here. XD is a terrific screen for larger/farther viewing distances. It's my go-to for those rooms.
I also recently took a close look at Elite's new 4K material. It's nice, but like all 4K materials I've seen so far, it doesn't have the gain of XD. If you can sit farther than 8'-10', XD is terrific for 4K or 2K.
post #1674 of 2117
Very happy to read these reports. Soon to install my 130" wide XD screen. Front row is at 11-12 feet, back row 5 feet behind that. Can't wait to start watching scope movies the way they're supposed to be seen!
post #1675 of 2117
ARGH! My new Seymour-Screen Excellence EN4k motorized screen just jammed up while opening. About half way through the opening cycle, one side continued to drop while the other bound up. I stopped the motor as quickly as I could but now I have the stuck side 1/3 of the way open and crinkled up while the other side is 1/2-to-2/3rds of the way open. Briefly toggling the motor between open and closed makes it clear the motor is working but fails to unjam the screen. Gently tugging on the tab-tensioning wire on the jammed side doesn't accomplish anything either. I've left a voice mail for Chris. Any other suggestions?
Happy Trails!
MTB Vince
post #1676 of 2117
Has anyone attempted a gray xD screen (via spraying, or....???) ???
post #1677 of 2117
No. But I strongly suspect that any coating on ANY AT screen (fabric or perf) will negatively impact the audio characteristics. I suppose one could be sprayed (but for what purpose?) if it were not being used as an AT screen.
post #1678 of 2117
There are companies that make gray AT screens. For perforated screens Stewart is a great choice with many materials available in their micro-perf, for a weave screen look at Vutec's Greydove Soundscreen material.
If you are looking for just the material that might be more difficult, I'm not sure if Vutec will sell the material only. You'd have to call and find out.
post #1679 of 2117
Anyone heard from Chris? I have sent several emails over the last few days trying to place my order and have gotten no response since the first reply with the price quote.
Chris if your reading this please double check your spam or junk folder, there are likely 3 emails from me (Scott)
post #1680 of 2117
If you just want darker, put on some sunglasses. Gray screens just darken everything down. While we could use gray threads (even though getting their color temperature accurate is very tricky), I'm not sure what it would accomplish. The worst ones are the ones that just alternative white and gray threads: lower FtL, much more texture - those give AT screens a bad name.
The only AT screen that would visually accomplish something - ambient light rejection - is the Stewart Firehawk. Just make sure you're sitting far enough back, and think twice about doing that to the audio. It's ~90% NON-AT.
The S-SE Enlightor-4K is technically a light gray since it's gain is under unity. Let me know if you need samples.
Cheers,
Chris
  Back to Forum: Screens
