AVS › AVS Forum › Display Devices › Screens › The official SeymourAV center stage screen thread!
The official SeymourAV center stage screen thread! - Page 58
post #1711 of 2117
Originally Posted by blipszyc View Post
Am leaning toward one of these screens but had a question about what can be seen behind it...will speakers with gloss or piano black finishes cause problems? Looking to get B&W CM9s but haven't honed in on a finish yet.
You won't need the black backing with those speakers. It's usually easy to darken things enough for the XD to be used solo.
Chris,
Chris
post #1712 of 2117
Originally Posted by ADDUpstate View Post
How did you test for the impact the screen frame was having on the sound?
I have two 15" front firing subs behind the EN4K frame and screen and the screen frame is in front of the subs, some screen above and GOM below. I haven't noticed any difference from before I put the larger screen in where the frame crosses the sub driver.
I ended up using the sweep test from the AIX test disc to locate dips and frequencies that excited subwoofer related rattles and distortions. Moving the Sub Up on a concrete block reduced audible problems quite a bit in this one case (smoother response, less distortion)
Behind where the bottom of the frame is a solid hard-wood 4x6. Since this cant be moved, I cant say conclusively if it is that that was really the issue, or moving the sub-woofer further from the floor had the larger impact. Other than that is a similar setup; Screen above, GOM below. Only the one sub though.
post #1713 of 2117
has anyone tried to attach the screen frame to the screen wall with velcro? this would enable you to forego using z-bars and drilling mounting brackets into the back of the frame. just trying to think outside the box! lol
post #1714 of 2117
You don't need to mount anything to the frame if you use the mounting kit provided. It hangs from the top section of the frame.
post #1715 of 2117
If you are building your own frame, like I did, there would be some advantages to a Velcro attachment method. I went with 2 Z-Bars, and they made the top of the frame stick away from the false wall due to their design. I knew that this would happen, so I just "propped" out the bottom with little rubber cabinet bumpers (about 1"x1" self stick square pieces that I stuck to the false wall framing)
Velcro should work, but the trick will be:
1) You want enough Velcro so that it sticks and doesn't slowly slide down over time.
2) You don't want too much Velcro that you have a hard time getting the screen removed from the wall.
Maybe some system with a small ledge or even pegs at the bottom to hold it square and support some weight, and then some small Velcro pieces at spaces around the frame to hold it against the false wall.
Just tossing out ideas. The simplest seems to be just adding something to the bottom to push it out in order to make it vertical...
post #1716 of 2117
This is my situation as well. I'm not too worried about supporting the weight of the frame with velcro. The panels on my screen wall are secured with velcro and they aren't going anywhere! lol. Also, the panels are friction fit which will support some of the weight of the frame as well. I will try the velcro method and report back. Thanks so much for the info!
post #1717 of 2117
Just remember that Velcro is a strong thing. You can always add more, but too much can be tricky.
I would actually recommend putting the "fuzzy" side all the way around the frame, and then just put the hook side in smaller strips on the false wall. That way you don't have to get things lined up 100% perfect.
post #1718 of 2117
Here's a great CIH installation over in the Dedicated HT forum:
http://www.avsforum.com/avs-vb/showthread.php?t=1411861
The only thing I'd suggest is to try and darken down more surfaces, but this is a great example of a very well thought out application and top performing equipment.
Cheers,
Chris
post #1719 of 2117
Ordered my 174" Seymour Center Stage XD Curved AT Scope Screen 3 weeks ago, hope to give my impressions soon.
post #1720 of 2117
That's a nice big screen, looking forward to your impressions - AND PICTURES!
post #1721 of 2117
Thought I would show a current picture of my set up. 107" wide curved scope screen with EN4K fabric, JTR T8 speakers behind the screen and a JVC RS45 with Prismasonic HD6000F lens.
[IMG][/IMG]
[IMG][/IMG]
The second inverted projector is my son's gaming projector. A 720 P Planar. The two subs in the front are DIY sealed 12" TC Sounds drivers and I have two more, largeer subs in the back of the room. All equipment is remote located.
Denon 4311
Four pro amps for speakers and subs.
Lumagen Mini 3D
PS3
HD DVD (A35)
HTPC (Intel I3)
Going from 16:9 to scope really provides the wow factor. Image is very sharp and detailed. I need to do some clean up, place the covers back on the electrical boxes and a little wire management. Black sound panels and bass traps behind the screen. The sound panels and bass traps at the back of the room are not white. They are gray. The black walls mess with the camera settings in auto and over expose the images, making the gray panels look white. Love the image on EN4K. Using the projector on normal (low lamp mode) cinema and have the iris closed down 3/4's of the way. Great looking image and sound in this room.
post #1722 of 2117
...Great looking image and sound in this room.
Show off.
Cheers,
Chris
post #1723 of 2117
[/IMG]
[/IMG]
Denon 4311
Lumagen Mini 3D
PS3
HD DVD (A35)
HTPC (Intel I3)
Is 107" big enough depending on seating? I have room for only a 105", and want to make sure it's worth it?
post #1724 of 2117
105" wide is a nice sized scope image. What is your viewing distance? To get that size of a scope image on a 16:9 screen would require a 121" diagonal screen.
post #1725 of 2117
I'm beginning to wish I went scope due to the height of 16:9 but I think i'll manage in the end
post #1726 of 2117
Seating can go back as far as needed. But I'm limited to height and width. I can get a wider screen by going 2.35. But my 16:9 image will suffer.
Thinking of seating around 12 ft or so.?
post #1727 of 2117
Screen size preference differs a lot between people - I'm at 12' from a 136" wide screen, and love it.
post #1728 of 2117
I am 9'-6" from the 107" wide. Try it at 12', you may be perfectly happy at that distance. You can always move closer later on.
post #1729 of 2117
I think you will be able to manage. Now quit trying to give us screen size envy.
post #1730 of 2117
My first row is about 11ft from a 120 inch wide 2.35 XD and I love it. Sony VW1000 for that distance helps too
post #1731 of 2117
I am 10'-6" from the 107" wide. Try it at 12", you may be perfectly happy at that distance. You can always move closer later on.
As Mike say's you can always move closer. If your 16:9 becomes smaller when you go for a 2.35 screen, just move the seats closer so they are at the same relative distance as a screen height to distance ratio.
For example, if your current 16:9 screen height to seating distance is around 3 to 1 (screen height is 4 feet high and you sit 12 feet back), and your new 2.35 screen is 3.5 feet tall, just move your seats so they are 10.5 feet back. That way the 16:9 image will look the same size visually as it did before from 12 feet back, except now, scope movies will feel a lot more immersive, as you've retained the same 3:1 seating ratio (you can go closer if you like, experiment to see what works best for you).
That's exactly what I did when I went from a 7 foot wide 16:9 screen to an 8 foot wide scope screen. From 12 feet back 16:9 did look small, but from 10.5 feet back it looked just fine, but scope movies were just so much more immersive and had an even greater visual impact.
Seating distance is very important when going for a 2.35 screen so that 16:9 isn't compromised.
Gary
post #1732 of 2117
Great info guys.....Thanks!
post #1733 of 2117
I couldn't get comfortable with a 2.35:1 size that supported the level of immersion I wanted for 16:9 - so went with more of a Constant Image Height setup, at 2.125:1 - a road less traveled, but I'm happy with it.
post #1734 of 2117
Are you cropping the sides of the image when watching scope? How are you constant height with a 2.125:1 aspect ratio screen?
post #1735 of 2117
Cheers,
Chris
Thanks Chris. Agree I should darken the walls & ceiling, Darn WAF biggrin.gif We love the screen. Guests who demo love the screen. Picture is wonderful. Definitely as advertised biggrin.gif
Also, thanks again for the tips on the Imax reveal. My blue LEDs do not appear to be as bright as those shown on your website but overall I'm happy with the outcome!
Edited by quack724 - 6/6/12 at 2:10pm
post #1736 of 2117
IMG_0135.JPG 2740k .JPG file
post #1737 of 2117
I am now going to have to place my Paradigm S8s and C5 Center very close to the back wall behind my screen, any suggestions as to anything I can do to help with the sound like maybe place a bass trap behind each speaker or at least accoustic panels?
John
post #1738 of 2117
2" fiberglass panels behind the speakers hsould work fine
post #1739 of 2117
That is one loooong box!
post #1740 of 2117
John
I think the latest is 1" JM linacoustic, 4-6mil plastic, 1" JM linacoustic
For the corners, triangle cut pieces of OC70x or an equivalent product...which products I'm not sure but I am researching since I can't find OC70x locally
  Back to Forum: Screens
