AVS › AVS Forum › Display Devices › Screens › The official SeymourAV center stage screen thread!
The official SeymourAV center stage screen thread! - Page 66
post #1951 of 2119
Just got my XD material today. I had a buddy come over and help me install it. I have a curved screen and I am using the Screen Tight method. It went relatively well. I thought it would be a good idea to install the screen initially on the outside channel. It turned out to be a good idea, as there were some very minor wrinkles that disappeared when running spline material through the inner channel. What I didn't anticipate was how much we pulled the top and bottom of the screen together. Initially there was some definite sag, but when I added my support braces, it was actually too tight, and the spline started to come out on the bottom. So, we removed the supports, drank some beer and watched the first part of Skyfall. I decided it would be a good idea to leave everything "as is" for a week or two and see if there is any relaxing of the material. Then, I will add my braces back into the equation. If the relaxation of the material isn't as much as expected no biggie - I can hack off a bit of the supports to the point where they won't be pulling out the spline material. Currently there are a few very minor wrinkles at the edges that need to be attended to which amazingly aren't even noticeable while watching a movie. As it stands, the PQ is head and shoulders above my old screen - it is bright, crisp and the sound comes through it loud and clear.
If I were to do it again, I'd probably go with the grommets/o-ring method, but hey, I already had the screen tight installed, so...
I'll post pics in a bit here. Damnit Skyfall does look great on it, though!
post #1952 of 2119
post #1953 of 2119
Damn you - Skyfall isn't released until March 27 here in Aus. Stupid movie studios!
post #1954 of 2119
Originally Posted by MikeyD360 View Post
Glad this is not something I will have to worry about with my XD screen.
I know that Seymour has the ability to cut their screens at an angle to aid in preventing moire, but the screen I ordered is about 150-156 inches diagonal. Chris told me that was too large to have cut at an angle. I don't know what the largest screen is that can be cut this way, but my size is too large.
I'm hoping I don't have moire issues. I won't have the screen up and projector mounted for another month or two.
post #1955 of 2119
Chris,
Can you post a picture of the economy frame in comparison to the premiere frame.
post #1956 of 2119
Originally Posted by wildcat91 View Post
Chris,
Iso shot. The edges were paint-penned a little along the front so the cross section looks weirder than it is.
Straight on:
Cheers,
Chris
post #1957 of 2119
Originally Posted by dropzone7 View Post
I was just checking in on the SeymourAV site, dreaming as usual about finally having a screen when I discovered their new "Economy" fixed frame product. I decided a while back to go with the Centerstage material but figured I would do DIY to save money. With this new option it makes buying the whole package from Seymour more appealing and frankly, better for my budget or lack thereof. One thing I'm not clear on is if the frame is still made of aluminum or if it's something else. Having the rubber band and post system would really be nice and I wouldn't mind the split in the top and bottom pieces at all. My room is so dark it would probably never be seen. As luch would have it, it's available up to the exact size I was looking for (130" wide 2.35). I'm also wondering if there is some sort of cross member or support bar in the middle of the frame.
I used visual apex frame from a 120" screen with Centerstage XD without any modifications. As an upgrade this seemed like a no-brainer. But if one is looking for a sturdy aluminum frame without vertical support bars in the middle, VA screens maybe a cheaper alternative to the Seymour "economy" line even at full price. They are only available in 16:9 aspect ratio though.
FWIW.
post #1958 of 2119
Originally Posted by Yzfbossman View Post
Hi Chris, I would enjoy hearing about your testing if you were able to get it done.
Sorry for the long delay. My meters and I were overdue for some quality intimate time together.
Here is a general top-down view of the A4K top left, Dazian's Celtic Cloth on the lower left, and Dazian's Coated Celtic Cloth on the right. There were several posts in the DIY forum up until around 2008 as it was a fairly popular DIY AT material. Simply search "CCC" when you have some PTO time to burn off. It was a pretty mediocre material that had low gain and wasn't very A.T. (-3dB started at 8kHz). Still, like the spandex screens they're currently playing with, for small screens where you're sitting up close, it can do the job. Be careful with interpixel light bleed through these types of materials, which can be seen as a haloing effect around something white on a black background. They also must have black backgrounds behind them or else additional light contamination from the back will further reduce the contrast ratio. Typical cost for CCC or spandex screens are about $60 of bulk material, so if you have expectations around the value point of painted screens, they can meet those expectations.
A little bit of the reference target is peeking out at the bottom so I could do a white balance correction. It's perhaps a tad overexposed but the balance is basically there.
Regarding gain, without any scaling or benchmarking to other materials (an unfortunate reality of practice these days - I may start rating things both ways), here are the test results:
Elite A4K: 0.69
Dazian Celtic Cloth: 0.72
Dazian Coated Celtic Cloth: 0.74
A valid question would be what the heck Dazian is coating it with, as nothing was visible to me. No additional sheen or anything, but the meter was picking up a tiny increase in brightness and a more accurate color. The color temperatures of the three materials are hard to see but here's the measurements:
Elite A4K: 6954 degrees, R: 96.5%, G: 97.3%, B: 106.2%. Essentially, too cool a white but I suppose if you're going to market a dim screen material having a slightly cool temperature can make it appear brighter since the eye is more sensitive to blue.
Dazian Celtic Cloth: 6765 degrees, R: 97.2%, G: 99.5%, B: 103.3%. Closer... This shows that while the weave, density and thread size appear identical, the thread itself is better.
Dazian Coated Celtic Cloth: 6593 degrees, R: 99.6%, G: 98.8%, B: 101.6%. Nailed it. This is essentially a pure white screen, which is likely why (along with its cost) it was quite popular in the DIY forums like the Wilsonart laminate.
A little closer shot:
Even closer ...
And a very close one at some angle so you can see how the weave pattern is the same, 100% polyester PFR.
I didn't measure the acoustical transparency of the Elite, as I assume it's similar to the CCC. These kinds of thicker weaves need to be stretched tight so they can open up and the transparency improves. Perhaps for proper sonic transparency Elite intends for their customers to have to stretch the material like this customer's third A4K screen from them:
Long story short, you can have a brighter, more color accurate 4K screen by making a Dazian CCC screen for much less money. I'm also guessing that you could put together a better fitting result.
Cheers,
Chris
post #1959 of 2119
FWIW.
Good to know. I'll put that on the site as a resource for those who need the total screen cost to come in even lower than our economy screen but aren't into wrapping wood frames.
Cheers,
Chris
post #1960 of 2119
Straight on:
Cheers,
Chris
Thamks Chris,
Decisions, Decisions. Looking at a 115" diag screen, contemplating whether to DIY the frame or go with the economy.
post #1961 of 2119
Am I crazy or were there no pics of the economy frame up on the seymour website yesterday????
post #1962 of 2119
Pics were there when I first stumbled across this last week.
post #1963 of 2119
That is a great attitude! I was a little worried if it was appropriate to post the info here.
Respect.
post #1964 of 2119
Thanks for the info Chris.
This CCC material is quite impressive for a cheaper DIY alternative.
Did you have a chance to measure the spandex?
post #1965 of 2119
Zheha - that looks pretty cool on the VA screen.
I have a 135" elite sable screen and the clip setup looks kind of similar. I am wondering if the same thing could be done othe Elite frame? Has anyone here tried that?
post #1966 of 2119
Why don't you get a free sample from Chris and give it a try? The fabric is fairly thick. If you manage to wrap it around the plastic rod, or whatever is used in Elite frames in its place, squeeze it into the groove and put the clip over then it's a go.
post #1967 of 2119
I believe I just might do that. I think I already have a sample around here somewhere. Just gotta find it...
Thanks for putting the idea out there!
post #1968 of 2119
Elite A4K: 0.69
Cheers,
Chris
Thanks Chris! I really appreciate you posting this up.
I have large samples of XD and Enlightor 4K hanging on my wall right now.
It might be in this thread but I can't find it.... what are your measured gain and color temp readings of XD and E4k?
post #1969 of 2119
For this round of testing and comparison purposes:
Enlightor-4K: unbenchmarked gain: 0.77, color temp: 6452, R: 101.2%, G: 99.0%, B: 99.8%
XD: unbenchmarked gain: 1.00, color temp: 6596, R: 98.9%, G: 100.0%, B: 101.1%
Cheers,
Chris
post #1970 of 2119
post #1971 of 2119
Ahem.... my backside is still smoking from accidentally mentioning 'Centerstage XD' over in "MM's forum" a few days ago trying to help a fellow out. I aint never going back over there.rolleyes.gif
post #1972 of 2119
I put together my 140" curved XD screen yesterday.
First, let me say that it is a 1 man job, a rarity these days.
The process is very straightforward and simple, and the unique way that the screen material is fitted via the rubber bands is foolproof. Instant and perfect tension.
My first row is about 8ft to the eyeballs and I cannot make out the material in broad daylight. I have to stand about 4ft to see it.
Perfect!!!
post #1973 of 2119
Perfect!!!
post #1974 of 2119
Shhhhh..He's probably listening in right now.
And by the way, Dropzone, not sure if your avitar is a picture of your girlfriend, daughter or yourself (ya right) but you're going to have to change it. Very distracting to us home theater geeks.tongue.gif
Edited by DavidK442 - 2/15/13 at 5:50am
post #1975 of 2119
Perfect!!!
Sounds great. Some more details please?
Did you build your own frame?
post #1976 of 2119
Ha! It's my wife. I can't tell you how many PM's I have received about that. I always let her read them and we have a laugh. smile.gif
Edited by dropzone7 - 2/15/13 at 8:28am
post #1977 of 2119
Haha, that sounds familiar. I created my "use Seymour fabric on a Jamestown frame" thread there initially (before the fabric was offered by James as an option), thinking it would be an option of interest to those considering DIY because they wanted to save money. Promptly got beaten up by the usual suspects. The folks there provide a great service, but are quite territorial.
post #1978 of 2119
LOL. Thought you just change the wife.tongue.gif:p
post #1979 of 2119
Remind me again what dropzone7's avatar was. Was it the swimsuit from behind at the beach?
post #1980 of 2119
Ha, I would be hard pressed to get a picture of my wife in a bathing suit. She doesn't like the sun or heat which is why she looks like Casper the ghost. If it were up to her we would live in the Arctic. She keeps the thermostat on 62 at night with fans pointed at us and I'm shivering under blankets. smile.gif
  Back to Forum: Screens
