Group,
I just installed a Seymour center stage retractable screen (2.35 to one; 105" wide). The screen quality and workmanship greatly exceeded my expectations
. The customer service from Chris was second to none.
The install went relatively well but I have a few recommendations:
* Make sure the mounting track is level with no bowing. Place a level on the track to make sure no dips are made after you fasten the screws into solid wood. If needed shim out the track to make sure it is flat.
* Don't even think about installing by yourself. I tried and quickly realized it is virtually impossible and dangerous. The 10' long screen only weighs about 60 lbs but it seems much heavier due to its length. With a helper is it easy.
I moved my couch to about 12 feet from the screen and the picture looks great. After watching a few movies I will update with a more detailed review.
Thanks for a great product Chris!
Jim
