I got my 42" 700u ISF calibrated this weekend and I don't really like the way it looks. Compression artifacts and noise are a lot more visible, colors are very dull, and the image doesn't have much depth. It looks a lot like using the "custom" image preset but with color at like -15. I also see much more color banding and dithering.
Cinema, though it's a lot dimmer, looks a lot better. i think I'll probably see about reseting it to factory defaults, because it's not an improvement.
Also, from what the calibrator said it sounds like the sets have some unique qualities that make calibration difficult. The color decoder on HDMI is apparently EXTREMELY poor. It had errors in a manner and severity that didn't make any sense to him. The gamma also had unusual qualities. He did think that the VGA input was relatively accurate.
That's suprising because I've read from other calibrators that the 700u can be almost perfect after calibration, while apparently mine is far perfect even after calibration. I wonder if the 42" version is significantly different than the 50" sets that are typically calibrated.
Will you be able to get back to your "default"? I can post mine if you want them.
