Wow, "Vivid" the entire time?!
Way too bright, and I assume consumes a lot more power. Cinema mode is often cited as being the most accurate out-of-the-box.
As to your specific Q: I'm not an expert but I'd imagine that changing the settings today would have virtually the same effect as if you did it day 1 in terms of changing the PQ. Though I'm betting so many hrs of Vivid have reduced pixel luminance a bit more (i.e. accelerated aging), thus you might not set the brightness as low as if done on day 1. This is all just educated guesswork on my part.
The following I wrote when I first read your Q. It might be of use to you though it isn't directly about your Q:
A lot of people swear by their ISF certified calibrations. Others will say you can get by with one of the calibration DVD's like "Digital Video Essentials". I got that one and I found it rather confusing and hard to dial in. The Pannys are noted for being a little weak in available adjustments. A professional calibrator will play with all the hidden service menu options to optimize. But at a significant cost.
Cnet has a review for the similar 42-px77u, and their suggested settings are here and aren't much different than mine: cnet link
Last, having written all that, I'll note the following:
While there is an "accurate" setting, people's tastes differ. While watching a recent president's address, I flipped between the 5 networks and the difference in color between them was astonishing. So regardless of whether the TV is set "perfectly", what does that really mean if each network/broadcaster/cinematographer has a different view on what is "proper"?
But I would get it off Vivid ASAP!
