post #1 of 1
I was wondering ...what subwoofer would you recommend ? My roomsize is 13.5 x 22.5 feet.
I have B&W Nautilus 803 front and a HTM1 as center.
Of the 3 models stated above, which one would you choose ?
Will the Boston Acoustics PV-1000 be enough for my room or should I go with the B&W 4000 to match the size of the room and the sound of the Nautilus ?
Anthony
