AVS › AVS Forum › Audio › Speakers › Optical vs Digital Coax
post #1 of 2
Need some help Would I be better off with using the Optical or the Digital Coax for my most used source. .
Thanks in advance
michael
post #2 of 2
Hi,
Neither optical or coax is "better" than the other, it's strictly personal preference. The only advantage of optical is the cables tend to be less expensive, however the trade off is they are more fragile which is only a concern if you move your equipment & cabling frequently. Digital Coax costs a bit more but tends to be more robust. As far as the quality of sound it's virtually the same.
Roger Kaufmann
  Back to Forum: Speakers
This thread is locked
