Just wondering if anybody had any feedback on the JVC JXS777 AV Selector. It has a bunch of composite and s-video ins and outs, as well as 2 component video ins, one component video out and three firewire input/output connections. I have been looking at different pre/pros and found that most of the high-end models don't have switching. Was wondering if anyone had any experience with the JVC since I definitely do not want to compromise picture or sound quality, Specs are below.
AV INPUT: 8 lines ( S-Video, Video, Audio L/R)
AV Output: 5 lines (S-Video, Video, Audio L/R)
Component input: 2 lines
Monitor output: 2 lines
DV input/outputs: 3
Optical inputs: 2
Optical output: 1
Processor in/out: 1 line
Video Frequency response: Composite 12 MHz, Component 30 MHz
Video Reference input: Composite 1.0 Vp-p (75 ohms unbalanced), Component Y: Vp-p 1.0V (75 ohms), Cb/Pb & Cr/Pr: Vp-p 0.7V (75 ohms)
Maximum video input level: Composite 1.0 Vp-p, Component Y: Vp-p 1.5V (75 ohms), Cb/Pb & Cr/Pr: Vp-p 1.0V
Video Crosstalk: 50 dB or more (45 dB or more between Y/C in the same channel)
Video S/N ratio: 50 dB or more
Audio Reference input level: -10 dBV, 47k ohms
Maximum Audio input level: +6 dBV (2.0 VRMS), 1kHz
Audio S/N ratio: 80 dB or more
Audio Output level: -10 dBV (with reference input, 1 kHz)
Audio Frequency Response: 5-50 kHz
Audio Total Harmonic Distortion: 0.01 % (with reference input, 1kHz)
Optical digital signal: [wavelength] 660 nm +/-30 nm, [output] -15 dBm - -2121dBm (at the end of reference level optical fiber output)
Power Requirements: AC 120V, 60 Hz
Power consumption: 15 W (Power On), 1.2 W (Standby)
Remote control unit (RM-AS700), SUM-3/AA/R6 battery x 2
Video Signal Format: NTSC
Warranty: 1 year parts 90 day labor warranty
DV input/outputs: 3
Optical inputs: 2
Optical output: 1
