Originally Posted by PPGPAUL
Yes , you will get into the service menu by just using 'menu' then '2-4-5-7. By entering '0' you will arrive at the 'Manual Keystone Geometry Alignment' . This will be the third selection down on the list of adjustments. . Press the buttons 2, 4, 5, 7, pause and then press 0 (Data Selection Mode will appear)
Make your adj as indicated in the above post.
Interesting. I'll give this a try when I get home from work tonight. Anything else worth sharing from the SM? Thanks!
GREAT FORUM!!
