AVS › AVS Forum › Audio › Home Theater In A Box › System for a gamer
System for a gamer
post #1 of 9
I'm looking for a system to hook up to my Xbox360 - I'm going to be using this #1 for gaming, then also for watching DVD's and maybe streamed movies from my computer. I also watch OTA HD using my TV tuner (that does have optical audio out). Right now the xbox is connected via components. I'm not planning on getting an HD/Bluray player until formats are sorted and prices drop, probably years from now.
I was excited about getting a HT-S790 for ~$300 after reading about it today, but it seems the lowest price is more like $450 right now. I have a 237V LCD, and sit about 10ft away, so a medium sized room. My reference point for audio is the Klipsch promedia 4.1 and 2.1 computer speakers that I thought were good stuff, I don't have any high-end home theater experience.
Budget is $350-500, I'm more of a "value player", in that I don't mind spending $500 as long it's a greal 'deal', ie. a system that normally sells for higher. Help?
post #2 of 9
You can get the 790 for $350 refurbished last I checked. Also I might suggest building your own system...Onkyo 504, Velodyne Frontrows, Dayton 10" sub should all come out to around $500 I think. Check the HTIB Alternatives thread if this interests you. People say it'll blow the socks off any HTIB.
post #3 of 9
So I picked up an HT-SR800 from CC today...all I can say is HECK YEAH!!! I paid $450 for it total, which isn't a great deal compared to the $300 HT-S790's that were around, but quite frankly it's bloody well worth it and I'm amazed! Beats the crap out of anything else I've owned, so I'm well chuffed.
Couple questions though:
-Is there any difference in high vs low priced optical audio cables? The only I have is a cheapo $16 Philips one from walmart that's actually translucent...should I upgrade?
-Are LCD's affected by the magnets in the center speaker? I'm wondering if I need to move it away from the LCD TV...?
-What sources take advantage of 6.1 or 7.1 systems? My xbox 360 only does 5.1
post #4 of 9
No you should be fine. The speakers are probably shielded anyway.
Some DVDs have 6.1 DTS (Lord of the rings extended for example) Many dvds have DD EX, which matrixes a back channel for 6.1 or 7.1.
There is no difference between optical cables. Digital is digital. Speaker wire would probably be a better upgrade, if you want to upgrade cables.
post #5 of 9
Thanks mate! I'm really enjoying this system haha (I know I know, it's not $5k top end gear, but it still sounds great to someone who's not had a real home theater system before, let me be excited ;-))
The speakers are indeed shielded, I guess I was just being paranoid for my precious LCD!
I didn't realize that you could get >5.1 on standard DVD's...since the Xbox360 only outputs 5.1 max, I may have to get a separate DVD player. Oh well, HD-DVD vs Blu-ray anyone? *grin*
Thanks, I'll look at some speaker wire from monoprice.com, hope they're as good as everyone says!
post #6 of 9
Pioneer 600W 5.1 Surround Sound System For XBOX 360 - HTS-GS1
http://www.walmart.com/catalog/produ...uct_id=5280864
post #7 of 9
What's the consensus on that Pioneer for the 360?
I'm looking for a relatively inexpensive (chuckle) HTIB for my 360 setup, with a 36" Vizio LCD.
One other thing to consider is that I'm leaning quite heavily to picking up the 360 HD DVD player. So I would like my HTIB (or whatever is recommended) to work well with the 360 & the HD DVDs.
Thanks in advance!
post #8 of 9
post #9 of 9
Thanks, but I'm all set with a TV. I'm looking for some recommendations for HTIB.
  Back to Forum: Home Theater In A Box
