AVS › AVS Forum › Display Devices › Rear Projection Units › Official Toshiba 65HM167 and 57HM167 Owner's thread
Official Toshiba 65HM167 and 57HM167 Owner's thread - Page 63
post #1861 of 3063
This tv has worked very well for me up until today. One of my 3 HDMI ports stopped working. I'm only using two right now so it's no big deal but I'll be getting a PS3 soon and will need that port back. Anyone have any problems with this. I could honestly just deal with this and when I get the PS3 I could move my DVR over to component. I'd be hard pressed to find a difference between HDMI and component. Question is, should I just deal with it or get it fixed if possible?
post #1862 of 3063
I am the proud owner of a 65" from the Sears Price Match.
I am having a problem although think it is a (Cox) cable box problem, not the TV. Just trying to figure out the best solution.
I set the code for the TV on the cable box remote. I can turn it on and off just fine. But as the remote flips to the cable box to change channels, if you hit power on the remote, the screen on the TV goes dark, but stays powered on. So you have to hit TV, then power. Basically turing both units off separately. I can remember to do this, but not sure everyone else in the house will. And with the lamp concern, I don't want to leave it on.
I tried plugging the TV into the outlet on the back of the cable box but it doesn't appear to be switched (not sure if it broken, or that is the way it operates).
The cable company said I need to put the right code into the remote that will power off both units at the same time. This doesn't work as I've tried every code Toshiba has listed.
When I called the cable company again he went to some other tech support guy. He said that the new remotes they have don't support turning both off, and that the switched power on the back they don't use it that way anymore, it it controlled by a signal. Not sure even if the switched power was working that would be good, since then the fan wouldn't stay on after power cooling it down.
In any case the cable company told me I have no choice but to power both off every time. It just doesn't seem right to me. I had a GE projection TV before and it worked just fine with one click it all shut off.
I never noticed it until the other night, the room was completely dark and I noticed the TV screen was very dimly lit (and the blue light was on).
Again I don't really think it is a function of the TV and maybe I should post in a different forum, but thought I'd start here to see if anyone has a similar problem?
Dave
post #1863 of 3063
Dave
I had this same problem with my other Toshiba and a Cox cable box. For some reason the Cox cable boxes remote just won't work properly with Toshiba tv's. I just ignored the issue and used two remotes. It was easier for me to tell my wife that she has to turn the power off on both remotes than explaining the other solution. However when I switched to DirectTV the remote for my HR20 DVR will properrly switch both off. Maybe a universal remote will solve your problem?
post #1864 of 3063
Anyone who has more than 2-3 components should invest in a universal remote, preferably a Harmony. The Harmony 659 works flawlessly with my Toshiba 65HM167, along with an HD DVR Cable box, an Onkyo receiver, a Blu-ray and an HD DVD player. Easy to setup, easy to customize and haven't had to learn a command yet. Best $79 I've spent yet.
post #1865 of 3063
i agree i have a harmony 880 i got about 6 months ago and i love it, got it on sale at bestbuy and it works great no having to find the codes and wait and do all that stuff, it just works....
post #1866 of 3063
Thanks for the info. I am really inclined to think it has something to do with Cox. I just tried a universal remote I had, and I can program both the cable box and the TV, but sure enough you have to power down each separately. I think I'll bring the cable box in and try and get some other model. I was looking at Satellite, but we have bunch of TV's in the house and it would end up costing more than cable.
post #1867 of 3063
ok here is a ? i just got the 65" I have been reading about the bulbs going up sooner then later. I was wondering if Toshiba sends you a replacement bulb do you have to send the old one back if it is still under warranty? Thinking about an extra bulb for future spare.
post #1868 of 3063
Yes, you do have to send the used one back. Toshiba's not that dumb.
post #1869 of 3063
Speaking of the bulb, where is the best place to get one, and what is the model # of the bulb?
post #1870 of 3063
I'm not sure where the best place is to get it, but just after I bought the TV and heard of the bulb issue, I priced them out. Basically $200 give or take. The enclosed link has the part numbers, there are some superceeded numbers too.
http://lamps-dlp.com/ProductDetail.a...umber=75007091
I just bought the Mack warranty today for $180 plus tax. I figure in three years the bulb will go out, so I figure I am buying the bulb now instead of later. I never buy extended warranties, but based on everything I read it seemed like a smart decision. Granted the TV might not break, or the bulb might not burn out, but within 3 years based on what I read everywhere the bulb will.
post #1871 of 3063
Hello all, my wife and I bought the 65HM167 in July and absolutely love it. My setup is a little ghetto at the moment lol as we currently reside with my mother-in-law while we save to buy a home of our own. The only problem I've had thus far with the tv is while watching some movies on Bluray via PS3 I've noticed the picture occasionally gets very grainy in dark spots, almost to the point that you'd think that the disc was dirty, when if fact, they are pristine. I adjusted some of the settings and the problem has cleared up some, but I still notice it, especially on Planet Earth. This grainy effect is not just in dark spots though. Its not so frequent as to ruin the tv, but having spent as much money on as we did, I'd like to not have it at all.
post #1872 of 3063
The disc being dirty and grain in the picture is totally unrelated. The grain you see in low light scenes is normal. It is also there in the movies when viewing in the theater.
post #1873 of 3063
its quite usual for even the very best Blu-rays to look grainy in a dark scene- thats common
post #1874 of 3063
yeah, i think it has to do with the current format that blu-rays are put into....there are even a couple of websites that have written articles on the subject. I think there is one on cnet
post #1875 of 3063
I want to make sure that placing large, floorstanding UNshielded speakers right snug next to a Toshiba 65hm167 is safe, and would not cause damage or distortion. I found the follwing explanation regarding this topic, and I just want to make sure.
Since unshielded speakers create problems only with CRT-based TVs, you shouldn't worry about placing your unshielded tower speakers close to an LCoS model.
from Sound and Vision Magazine, regardng a LCOS TV
Is this true for the 65HM167 as well?
post #1876 of 3063
I recently bought a 65hm167 at Sears. I used their pricematch policy to buy it for $880.00 plus tax. I also purchased their extended warranty for 3 years for $399.00, which includes bulb replacement. Is it better to purchase the 5 year replacement for about $150.00 more? This is my first projection TV.
post #1877 of 3063
when did you buy it and who did you price match with? because if so i will go back and get the difference that i paid...
post #1878 of 3063
$150 more for 2 more years is a good deal. Especially since Toshiba doesn't make RP sets anymore. Sony has also stopped making them and in 5 years no one will probably be making them.
But it is still a personal decision. You already paid $400 for 3 years. $150 for 2 more I think is worth it. But it also costs more than half the price of the set.
For me I bought an extended warranty from Tapeworks for $210 for 4 or 5 years. But I also paid $1700 for my set back in June.
Since you paid so little for your set you could check out getting the Tapeworks extended warranty. We get an AVS discount.. You paid so little for the set, and the extended warranty from Sears is extremely expensive as a percentage of the cost of the set.
But if Sears will replace the set with a similar size if there are problems the Sears warranty might be worth it. It 5 years they would have to replace it with an LCD set. And by then they will be really inexpensive. They are already down to $4k for a 65" Olevia LCD. I paid that much for my 1080P DLP in 2005.
post #1879 of 3063
Hello, I'm trying to replace the lamp in my 57hm167, and I've tried about 6 or 7 different screwdrivers and have not been able to get the lamp housing out. Even though it's a philips head screw, it's grooved just strangely enough that an average screwdriver doesn't seem to be working for me.
Anybody replaced their own lamp? Can anybody tell me what size or type of screwdriver worked? Much appreciated.
post #1880 of 3063
Hi all 1st time poster here. This is the most informative site ive seen on these TV'S. So thanx to you all. Anyway i need a little help here. I bought the 65HM167 last June and love it. My question is with HDMI. I currenly have a regular HDMI cable from Direct TV HD Box to my TV, and an optical from my Onkyo 7.1 to my Direct Tv Box. My Onkyo does not have HDMI port. Would a 1.3 HDMI help me in any way, picture,sound etc. Also are the expensive HDMI'S really better for a 3 foot run? My father and i argue about this all the time. Thanx alot everyone. Any other ideas on set up for pic and audio quaulity is appreciated. Current set up 65HM167,,, Onkyo HT-S790 7.1,,, Direct TV H20.
post #1881 of 3063
Just use HDMI to the TV from your DirecTV box. And use the optical out to your receiver. That way you can get multichannel audio from the receiver if you want, or just stereo audio from the TV. I don't have the DirecTV box but all the 20+ HDMI devices I've used the last 2.5 years have all worked this way.
For HDMI cables go to monoprice.com.
VEery inexpensive and will work the same as a $100 HDMI cable. I'm using around 24 of their HDMI cables right now without any problems.
post #1882 of 3063
Thanx. What about regular HDMI VS 1.3?
post #1883 of 3063
Sorry to ask again. Do i need a 1.3 HDMI for this set up. If so why,, what benefit ? Thanx
post #1884 of 3063
No. All but the worst quality HDMI cables will work with 1.3 and if they don't you will know it. Plus, besides bitstreaming HD audio, features like 1.3's "Deep Color" aren't used in HD DVD/BD and may never be. Slapping "1.3" on a HDMI cable is like slapping "Digital" on a video cable and selling it as "Digital Coax Audio".
post #1885 of 3063
Originally Posted by kfarzin View Post
What do you guys think of this stand from BB:
http://www.bestbuy.com/site/olspage....#productdetail
I checked it out at the store tonight and it looks pretty good being all glossy black and the width is exactly as the TV. The only issue I'm concerned with is that the height is almost 23". This stand will sit in my media niche which is already raised 9". So the TV would be sitting 32" from the floor. Do you guys think this would affect my vertical viewing angle? I will be sitting 12-14' from the TV. Right now I have a Sony 55" LCD RPTV sitting 29" from the floor and have no vertical viewing issue. Any comments??
I have that stand. I think it is just right on the floor or I wouldn't even mind it a little lower. The stand is very nice. However with extra 9" would be too high. Unless you like looking up at the screen don't do it.
post #1886 of 3063
Well I went with that stand and have finally put everything in place and it seems fine. I guess sitting 14 feet from it makes up for it being a bit higher. But then again my last Sony 55" was about the same height (2" lower) and I had no viewing issues. The stand is definetely a nice stand. Very solid.
post #1887 of 3063
I have a question about Cinema Mode and I'm pretty sure I already know the answer. I'm asking anyway in hope that I'm wrong. I initially assumed each input source would maintain unique settings but it appears that only the "picture settings" are maintained per source. I would prefer that when the source is set to receive a signal from the Dish receiver that Cinema Mode would be Video and that when I switch to the HD DVD player that it would be Film. However the Cinema Mode setting looks like it applies across the board (i.e. when I change it for one it changes for all sources).
Am I missing something? Don't you think it should retain unique settings?
post #1888 of 3063
Originally Posted by vhato View Post
Sorry, I dunno how I missed this: OverScan as being an equal loss of resolution verticaly and horizontally is uneditable on the ##HM167 series. It is "fixed" in the lens array. However, if the picture just isn't centered (as mine was) then this is the fix for you!!
These are settings from the 2006 model year. When you enter your service menu you will find *more* settings.
1. Turn volume to minimum
2. Press mute twice on remote control
3. Press mute button again and hold button down
4. While continuing to hold MUTE on remote, press MENU button ON TV SET
You are now in service menu.
How does one see the number of hours on the bulb from the service menu?
post #1889 of 3063
I'll have to check this out tonight. I thought my set saved the settings for each input, but maybe I am dreaming that. I'll check tonight and let you know what I find.
post #1890 of 3063
Thanks. I'm interested to know. If your does allow for you to have individual Cinema Mode settings per source input that something is wrong with mine (firmware? can it be updated?). I'd actually that be the case rather you responding that yours is working exactly as mine is because that obviously means we're stuck with one Cinema Mode across the board. If so that's a miss on Toshiba's part IMO.
  Back to Forum: Rear Projection Units
