Originally Posted by
broketoo
Alright what you're basically saying is...
If I am watching 1080i program ABC via built-in tuner and it's saying 1080i on the status bar, I am not really seeing 1080 lines??
Yes, but only when watching film-based programs like CSI, ER, movies, etc and HD DVD/BRDs on players limited to 1080i60 output.
However, you should be aware that the loss of resolution is not an all or none scenario. When there is no movement you still get full 1080. It is when there is movement, that the resolution starts to drop. It can drop all the way down to 540 if there is a lot of movement and it is most noticeable during horizontal pans.
All 1080i video-based programs (regardless of source) do just fine with this TV and stay at 1080 since this sets passes the HD Video Resolution Loss test.
broketoo
If I plugged in the upconverting DVD player that output 1080i, I will not see 1080 lines? And it would makes no difference (if any) with a player with Progressive scan that output 480p?
Since this is a 1080p set, you always see 1080 lines no mater what the source. The issue is that not all of those 1080 lines are discrete depending on the source signal.
A DVD is a 480i source. All an upconverting DVD player does is take the 480 lines worth of resolution on a DVD, deinterlace it, and upscale it to 1080 lines. The player's video processor does the deinterlacing and then interpolates (makes up) the additional 600 lines required for upscaling.
Any 1080p TV does this exact same thing when you just hook up a regular 480i player. However, the earlier TVs didn't do it very well since the internal 480i video processors were lacking. The upconverting players used better processors and were introduced so that the TV's processors could be bypassed.
However, an upconverting DVD player is typically no longer necessary since the latest generation of HDTVs have 480i processors better or equal to what you find in most sub $300 upconverting DVD players offered today. Most HDTVS offered today deinterlace and upscale 480i quite well.
