Originally Posted by jodeci4l
After much soul searching, i decided to take the plunge. I ordered the 57, and its on the way. The thing about 1080i really layed heavily on my mind. Why would you want a tv that didn't display full HD and HD DVD resolution(I own A1). I took a final stroll to my local BB And CC. And i just couldn't deny the picture, It has that extra umpf thats hard to describe, and resolution isn't everything. But i'm still interested in getting the most out of 1080i signals. I did some searching and i saw gefen has a new scaler. http://www.gefen.com/kvm/product.jsp?prod_id=4174. I wonder if it would convert 1080i to 1080p and not lose any lines of resolution. No it isnt a $1000 plus scaler, but the specs look good for the money and gefen has fixed all reported problems through firmware updates.
The Gefen scaler would work IF it does 1080i IVTC (film-source deinterlacing)correctly and 1080i video deinterlacing correctly.
I looked at the manual and it's ambiguous. It says, "Automatic 3:2 pull-down & 2:2 pull-down detection and recovery." This is another way to say IVTC. I'm sure it does IVTC correctly on the 480i inputs - what you need to confirm is if it does IVTC on the 1080i inputs as well. The 1080i processing takes much more computational power.
You would also need to confirm if the video deintelacing is using both 540 line fields from the 1080i inputs to generate the 1080p output. Gefen calls this, "Dual 3-D motion video adaptive de-interlacers with smooth low-angle edge." Cheap video deintelacers only use one 540 line field and discard the other - the result is 540 lines worth of resolution with artifacts with a 1080i video source. If the Gefen is only using one field - it's video deintelacing would actually be a step down from the Toshiba, which does it correctly.
Summary: The 167 line handles both film and video sent as 480i correctly (i.e. any type of DVD sent as 480i). It also handles video sources sent via 1080i correctly. The only place it falls short is with film-based sources sent as 1080i.
Video game frames (which are generated progressively like film) sent as 1080i will also result is resolution loss. This is true for ANY TV. Setting the game console output to 1080p eliminates the deinterlacing step within the TV. Therefore, the game console output should always be set to 1080p to maintain full resolution to the screen.
. That puts a crimp on my plans tomorrow. I was hoping it would be delivered in the morning. If I could have scheduled a time like that I could have had it delivered on a weekday and left work a little early. And I would already be ejoying the set.
