Originally Posted by Kpilk
Thanks. I got everything together and it works fine. In the auto position and with the system off, therefore the sub amp off (red light) it still maintains some heat. In the OFF position, it really is off and puts off no heat. When its running with the system it doesn't seem to get any hotter. Its not 'hot', but just putting out heat when not in use. Seems strange to me. I will keep an eye on it and call Outlaw and ask them a few questions.
Not sure about this unit. Got everything hooked up correctly. The sub is putting out very little. It is running but I can switch it off and nothing really changes as far as output. Putting my hand on the sub and it is barely moving. Disappointed to say the least. On the bright side, the Sierra's were worth the wait. However, now I'm up against the 30 trial period on the Outlaw. I am thinking I may go another route, something a bit bigger. I suspect that this is a bad unit given the heat output when off. Anyone else have a suggestion? I really like the Compact for its size and down fire/port design. Is it worth dealing with Outlaw or should I just send it back?
I believe that your amp is malfunctioning. If you can handle the job, get Outlaw to send you a new amp and swap it out. 10 minute job, very simple.
