AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official Outlaw Owners thread
Official Outlaw Owners thread - Page 131
post #3901 of 6828
Originally Posted by crazyjutt View Post
thanks
should i leave plug in the sub or take it out before running MCAAC ?
Also, i only see one plug shipped with sub. am i supposed to have two ?
read the manual it'll answer that for you.
Here's the best piece of advice for EVERYONE here who has questions. We will all be happy to answer questions but if you just READ THE MANUAL you'd be surprised how much Outlaw provides to begin with. It's not that long of a manual and it's written in lay-man's terms.
Just saying...
post #3902 of 6828
Just saying...
+1
If you are new to this, then without reading the manual, you won't even know what questions to ask.
Also, here is a guide that goes a little beyond what the Outlaw manual provides that may answer additional questions.
post #3903 of 6828
Just saying...
You mean Outlaw didnt hire Denons guy to write the manual???
Also guys if someone tells you to RTFM its just a short way of saying read the effin manual
post #3904 of 6828
No. RTFM means "Read the Fantastic Manual" to anyone that doesn't know better
post #3905 of 6828
Originally Posted by chashint View Post
I would think you could hear a difference in the sound especially in hearing different volume levels of the source material by going from -13 trim to -5... that is a huge improvement in itself.
The Radio Shack SPL meter is pretty easy to use.
Mine is the one with the analog meter so if yours is the digital model it may be a little different but in the end it will do the same thing.
Set the weighting to C, set the response to slow, set the range 80, on the analog meter 0 on the dial = 80db SPL, add or subtract the numbers depending on where the needle is sitting to get the correct dB SPL.
I have not seen the digital meter but chances are it displays the correct SPL without needing to do any math.
Most AVR auto cal programs try to set the speaker level to 75 at the mic position which is where that number comes from.
To set the sub level using the AVR test one (noise) set the subwoofer channel trim to 0, adjust the sub gain control to 1 or 2, turn on the test tone and measure the level with the meter.
Adjust the sub gain control until you get 75 at the listening position.
The mic of the SPL meter should be pointed up and it should remain stationary until you are finished using it.
That's about it.
The C weighting is a correction table based on frequency, google it if you want to know more about it.
The meter uses the C weighting correction and I think its plenty close enough without using additional correction tables.
Your mileage may vary on that, but if I add the popularly published correction factors for the RS SPL meter I get crazy response numbers that just can't be true.
before i start using the SPL meter does the receiver volume knob have to be at a certain volume?
post #3906 of 6828
Not if you mean -10 or some other arbitrary level on your receiver, however, the actual sound pressure level seems to be at 75 db as measured on the meter.
post #3907 of 6828
Originally Posted by Test123455 View Post
I ran Audyssey again with the gain at 3 and AGAIN it set it to -15db!
The more correct value is like -3 to -4db though. I guess Audyssey just thinks the sub is way too much for my 1560cf room (and doesnt know what level to set the gain at for subs on 2EQ).
wow. that sub is gonna destroy that room.
do you have anything under the sub? if you have wood floors, it's a good idea to put a small rug/welcome mat under it. if you have a rug in that entire room, forget the welcome mat and just lower the gain a little more.
post #3908 of 6828
Ok the EX is a Major improvement. Is it wrong to want more? I want more BASS!!!! Lol. Thanks for the help guys.
post #3909 of 6828
Yeah, maybe you need to lower the gain even more.
My HT room is larger than yours at 2700 cu ft (w/ 6 foot opening in the back corner of the room to another similarly sized room), and my subwoofer is in a corner about 12ft away from the listening position. I have to set the gain on the EX to around 2.2 to get a decent trim in Audyssey. It was on 4 before, but after the getting Gramma I had to lower it some more.
I am running Audyssey (MultiEQ XT) which EQs the sub. With the EX gain at 2.2ish, my receiver, after running Audyssey, set the subwoofer trim at -2.5db. When I had the gain a little over 3, the trim was set around -6db. At 4, the trim was set to -12db (which is bad, as the trim ideally should be somewhere less than -12db, hence why I lowered the gain to 2.2/2.5).
The EX is a beast. I can't imagine what the Hsu VTF-15h would be like.
post #3910 of 6828
You know, I am glad to help but you are not doing what I am suggesting so at this point the best help I can give you that will actually do you some good is to say.... RTFM for the AVR, the sub, and the SPL meter.
post #3911 of 6828
I don't understand why it is so hard to turn the gain knob closer to 0.
Turn it down to .5 if you have to, but get that auto cal trim setting +/-3 from 0.
post #3912 of 6828
It won't matter what you have the volume nob on the rec set to.The receiver will produce the tone.
post #3913 of 6828
i think i am going to get another EX down the road
post #3914 of 6828
It's psychological. You pay a lot for a sub and have to set its volume at seemingly less than a 1/4 of its potential. Not easy to do but I am in the same boat. I started with the volume at the halfway point and the AVR struggled with it and now I am near a 1/4 and it still needs to be lowered. I haven't had time to rerun Audessy but probably will this weekend.
post #3915 of 6828
Look at it like ... wow my sub is so powerful I only need to have the amp set to 1 if that helps get past the mental block.
post #3916 of 6828
That's where your thought process is wrong. That knob isn't a volume knob it's a "gain" setting. Think of it this way, it's got all that room to increase gain if your setup requires it.
I have mine set somewhere between 1 & 2 and just for kicks I played a 20Hz and 35Hz test tone and put my AV receiver to -15dB volume level (sub is tuned to -3dB and I run it 3dB hot so it's set to 0dB)
Whole room was shaking and it's an open 30x15x12 room. So yea, no worries the sub has plenty of room for power at a "low gain".
post #3917 of 6828
I must be an idiot because I had my speakers set to small 80Hz and the RS analog set to 80 as well. In order to get the spl meter needle to zero I had to turn up my avr test tone volume to zero as well.
post #3918 of 6828
but then you wonder, after you set the sub to 1, did I really need this much sub?
post #3919 of 6828
So you're saying that lowering the gain isnt really limiting the sub in any way? I was confusing the volume knob and gain knob. Apparently they are not the same.
post #3920 of 6828
Hey nuzzy, you are not an idiot...
I have two different AVR models and on the one AVR, the volume control has no impact on the test tone volume and on the other, I have to set the master volume to 0.0 to get a proper test tone...
Also IIRC, on a RS analog meter, you want to set it to 70dB and wait for the needle to hit +5dB or 75dB...
post #3921 of 6828
Yes...I have a Onkyo 805 AVR and the sub out sends a very hot signal to the amp on the Outlaw. If I run a sub trim level of 0.0dB, I start having a clipped signal. So I turn down the sub trim level to -10.0dB and to compensate, turn up the gain of the Outlaw sub. My gain is set to "4" at the moment...
This still produces a 75dB reading at my LP.
post #3922 of 6828
correct.
If psychologically this helps you think of it this way. Your receiver is assuming you have a very weak sub so it's sending out a very strong signal. Your outlaw is so powerful that it doesn't need that strong of a signal so your gain is set very low. Works?
post #3923 of 6828
correct.
the all-powerful EX. I guess part of the confusion is that the gain knob is labeled volume knob on the Outlaw, but I see what you mean now.
post #3924 of 6828
I have both an EX and a PLUS for dual Outlaw bass bliss. After Audessey calibration which sounds great, both my subs have their gain knobs between 1 and 2.
post #3925 of 6828
So this seems to be normal. That is good to know.
post #3926 of 6828
Quick question. My carpet isn't super thick. I currently have the discs on the sub. For those of you with carpet not so thick, do you get better results with the discs on or just the pointy feet?
post #3927 of 6828
will the LFM PLUS play nice if paired with the LFM EX?
or is it better to get another EX?
post #3928 of 6828
They blend perfectly. I purchased the PLUS after having the EX originally for space issues and WAF. I told the wife I was getting another sub but a smaller version of the EX. Part of the sell job. The PLUS is a little smaller but has same size driver and amp.
Now I have the EX in the front left corner next to my left tower and the PLUS in the opposite back corner next to the couch. The room rocks!!
post #3929 of 6828
I was wondering about this also as I have the Plus and would like to get the EX in the future after I get my house sold. Since the EX goes a little deeper than the Plus do you ever hear (or feel actually) a difference between the two?
post #3930 of 6828
Anyone?
