AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official Outlaw Owners thread
Official Outlaw Owners thread - Page 149
post #4441 of 6798
Mmmm... *drool* this... is nice...
post #4442 of 6798
The protective paper on mine was somewhat difficult to get off, but it did not leave any residue so it could have been worse.
post #4443 of 6798
Try rising the sub about an inch higher. Might be amazing mod!
My sub is on carpet which is over concrete so I dont need a sub pad but wonder if raising it up would improve the sound. Right now I have it on the spacers that came with the sub...Does rising it alllow more ummpphh?
post #4444 of 6798
Yeah, I'm already over the paper. Having eargasms at the moment
post #4445 of 6798
Most people report the bass being more tight when its rised. hsu gave me a long explanation about why. Basically its the same as moving the subs away from a wall(like 3 inches away)
post #4446 of 6798
Took me forever to get that paper off...hahah
post #4447 of 6798
Once I got an edge up, I just pulled slowly and off it came. I love this sub! Glad I didn't go and spend 1000-1500 like I was originally planning lol. Now I just need to figure out how to stop my room door from rattling.
post #4448 of 6798
Guys,
I have a quick question in regards to LFM-1 Plus & LFM-1 Ex. I'm trying to determine which one to buy. I guess my real question is - is the $100 additional on the Ex worth it? Or will I not notice that big of a difference? My initial budget was $550. With shipping/tax, the LFM-1 Plus far exceeds that but I'm still up for it. If the magnitutde of gain versus cost is high on the Ex, I will shell out the extra for it as well.
I do plan to, at a much later stage, add a 2nd Sub to make a Dual-Sub (7.2) configuration. Whichever Sub I get now, I'll duplicate at some point in time. But that could be a while so I still need to base my decision on the Single Sub right now.
My only other question - and this is probably the worst place in the world to ask this question - would be if there's any other sub that gives the LFM-1 Plus competition in the $550 range? Anything I should consider before jumping in.
post #4449 of 6798
I just keep my door slightly open. Only thing that kept it from rattling. My windows on the other hand look like they are about to break into a million pieces lol
post #4450 of 6798
Originally Posted by mickey79 View Post
Guys,
Hey Mickey,
If you get a plus you could get two in the long run and that would be cheaper. The plus uses the same driver but the enclosure is smaller which affects its ability to play lower. BUT I still think its a great sub. Bought one for my parents and couldn't really tell the difference between my ex. But more importantly though how big is your room?
post #4451 of 6798
I was thinking of drilling two holes in the top and one in the side and then filling it with spray insulating foam... but then again I don't know exactly how the door is constructed. It's about 50 years old and sounds very hollow. It doesn't rattle half as much as it does without the Auralex Gramma that I snagged... but I can still hear it faintly over my music. And yeah... I have one window that has a slight rattle at loud volumes... so annoying!
post #4452 of 6798
The main competitors are the Rythmik FV12, Epik Legend, and HSU VTF-2 MK4. As for the differences? That you'd have to research outside of this thread
post #4453 of 6798
Have you tried putting some kind of foam under the door when playing movies? I just used some left over packing foam from my subdude diy and it helped with the rattles
post #4454 of 6798
Hmm, will try. May also try a bead of caulk or silicone along the length of the door frame so it presses on the door when it is shut. That actually (theoretically) seems like it would be the easiest work around for now until I rip the house apart and do a makeover.
post #4455 of 6798
Hey Mickey,
Thanks man! I have definitely been leaning towards Plus just because of cost; at the same time - this is a Sub purchase for a long, long time to come and i didn't want to loose out on something over a $100. I'm definitely more encouraged to getting the Plus if the difference isn't all that much.
The room isn't tremendously large; I don't have the dimensions but it's your basic family room at this point.
Thanks -- I'll definitely look at a couple of these before making final decision. Most people I talked to told me Outlaw is a tad bit better then HSU.
Thanks!!
post #4456 of 6798
Don't quote me on this... but I thought the driver was designed by Dr. Hsu for the Outlaw subs?
post #4457 of 6798
Loft this is all you'll need to stop the door from rattling
post #4458 of 6798
+1 hahahah
post #4459 of 6798
He "consulted" with the outlaw designers. That's what the site says but pete still believes hsu is better hhah
post #4460 of 6798
*snip*
And then I'll have to climb out of said rattling window to leave, eh? lol...
post #4461 of 6798
Ah, I knew he had some involvement. Either way, I'm thankful.
post #4462 of 6798
I haven't ruled HSU out; and I'm aware of the "involvement" ... I've just found 2 people for 1 recommending Outlaw over HSU. If I were to get a crazy deal on HSU that saved me some cash - believe me - I'd jump on it.
post #4463 of 6798
If you're like me and live in cali hsu wins hands down local pick up haha
post #4464 of 6798
anyone know when the outlaw subs are likely to go back on sale?
post #4465 of 6798
The Plus has speaker level inputs, and you could have it up and running in a couple of minutes:
1) Hook up that sub speaker connection to the Plus, either the left or right input.
2) Set the switch on the back of the Plus to "Active" and the crossover frequency dial all the way up to 180hz since the Sony receiver will have already filtered out the high frequencies.
3) Adjust the gain (volume) on the Plus way down to start, and gently turn it up while listening to some good bass music until it makes you happy
Cel, im going to hook up the Plus tonight they way you suggested. I will be eventually getting a new receiver. But seeing the Plus sitting all alone and unused in the box, it made me sad.
Now my biggest concern will be about maximizing volume and sound from the Plus while minimizing disturbances to my neighboors. I live in an apartment, and my living room is about 11ft X 20ft X 8ft. I live on the second foor, but underneath me is a garage, so I dont mind the Plus downfiring.
Before I bought the Plus, I read everything I possibly could regarding Subs in an apartment setting. I didnt think buying a cheaper, weaker or smaller sub would rectify the problem. In fact, I thought this would compound the problem in that I would probably have to turn up the volume of the bass on the weaker sub....
I figured it was just worth it to get the Plus, and that way I could get a low, tight bass sound with out extraordinary volume levels. Anyways, I have my Gramma ready to go, and I just need to figure out the best place to put the Plus so that my upstairs neighboor doesnt kill me.
post #4466 of 6798
I just called today because I had some questions. I asked if they would be going on sale soon because I saw the sale on Facebook but that was going back to November. He said he didn't think anytime soon I was hoping he was gonna say "i can honor that price for you" No such luck Oh well I'll keep checking!!
post #4467 of 6798
I suggest right above their bathroom. I mean, well... that would be funny to me... but jokes aside I have no idea.
post #4468 of 6798
Ultra lows still still find there way to your neighbor. Id recommend telling your neighbor that you have a subwoofer and build some good repore with them lol
post #4469 of 6798
I did sign up for their newsletter at their website and it says they will let you know about specials to members. I am going to patiently wait a little while.........but then I have to get something.
Outlaw Audio Quick Draw Program
post #4470 of 6798
Haha, the neighboor above me already complained to me about my Sony HTIB being too loud!
