Originally Posted by mattdub1
Thanks, but sort of confused by the response.... If I turn the gain to 2 (from 3.5) on the sub then it will be less prominent (which isn't what I want). I have recalibrated several times and seem to be getting consistent results. I also have read numerous posts that say as long as audyssey isn't maxed out during calibration (+/-12), then it shouldn't be an issue. Unfortunately I don't have an spl meter to test, but am mainly wondering how many db I can increase the sub trim with the AVR before risking my sub? I have heard many people run 3 db hot from what audyssey sets the trim at, but is there risk in running 6 db or perhaps even 8-10 db hot as long as it doesn't reach the +12 range on the AVR? thanks
If you are at -8 in the receiver, then you have headroom in the receiver, about "20db" worth(-8 to 0, then 0 to +12). So essentially your receiver is sending the sub a really low signal(voltage) & the amp on the sub is having to do more work to amplify the signal. If you set the receiver at lets say, 0, you are then sending more voltage"Sub signal" to the amp on the sub & it has to do less work to amplify the signal. You probably would not overdrive it by setting the receiver at 0 & the sub at 4, but judging by the settings you have listed(if everything is correct) you would be roughly 10db higher in the lfe range. So crank away. To each his own. I highly recommend letting Audyssey calibrate your system.(Not that I'm a pro or anything, just an enthusiast), but if you have everything set-up correctly & follow the Audyssey guidelines it will do a good job for a home set-up. Then afterwards if you want to raise the sub 3-4db, go for it. For me I had a couple budget subs that even after running Audyssey basically just went boom boom(not actually playing bass notes, but making loud distorted sounds
but, after getting the Outlaw it was a clean non distorted sound that actually produced a musical note & it took a couple of week to get used to.Edited by cadett - 1/8/13 at 12:27pm
