Originally Posted by noisebeam
Of course, but that is not the question. What I am curious about is either if there is a known specific difference in output (at matched test conditions) between the two modes or what others are seeing as difference in their setups/rooms.
Also I assume that there is different internal amp EQ applied for each mode - hence the ME vs. MO switch. It could have been designed electronically so levels are matched at same output.
I actually did some measurements between the two modes. MO was way better in my room than ME. I will see if I still have the graphs.
