AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Wilsonart DW hotspotting??
post #1 of 32
I recently installed my Wilsonart Designer White screen that is 92" Wide and a 1.85:1 A/R My projector is a Sony G90 and overall the image looks awesome but one thing I have noticed is that I am getting some mild hotspotting right in the middle of the screen.
Has anyone else noticed this hotspotting issue witht the Wilsonart DW laminate??
post #2 of 32
Most folks dont have the luxury of a G90 to experience what your seeing !
I can only imagine what fine PQ your viewing !
Send a nice fella named Clarence a PM since he has the G90 and has a DW laminate screen. He has displayed some of the most outstanding still shots I have ever seen!
http://www.avsforum.com/avs-vb/member.php?u=7428394
If anybody knows your projector & DW screen it would be him.
post #3 of 32
to add to what Silverfox1 said:
No, I don't see any hotspotting, but I don't have a G90, I have a Z5.
post #4 of 32
Another thing to ask Clarence is how the projectors are mounted and calibrated. Compare that too and see if one is floor mounted vs ceiling mounted, and ask him for his calibration settings and the hours he has on his guns. If the run time is similar you should be able to punch in his settings and get the same or very close to the same image quality that he has been getting.
I know people over in the HDTV section compare and use others settings all the time if they have the exact same setup and equipment, so it is worth a try!
post #5 of 32
Thanks guys, I have a PM into him so I hope he responds.
post #6 of 32
How high is your projector mounted? I also have DW screen but I don't have any hotspotting because my projector, a Mitsubishi HC3000 and due to it's offset is mounted slightly above the top of my screen. If your projector is mounted too low you can be using the screen more like a retroreflective screen rather than an angular reflective screen. In the latter hotspotting is possible.
post #7 of 32
The G90 is ceiling mounted where the bottom of the lens is even with the top of the screen.
Before I put up the Wilsonart laminate I was using the painted wall which had basically zero hotspotting issues. Like I mentioned it is not horrible but it is definately there. I will take a picture of it tonight and post it here of a completely white window so everyone can see what I am talking about.
post #8 of 32
Hi Brian-
Yes, I can see a slight warmspot in the center on the solid white test pattern, not during normal content.
I'd suspect the effect might be even more noticeable on your screen since your projector is closer (92" on yours vs 115" on mine).
My tubes have about 8500 hours on them now... still running amazingly strong... about 2000 hours of 1080p last year. I've got a spare set of tubes ready and waiting in case these ever get worn.
Ken W did another great calibration on it a couple of weeks ago.
post #9 of 32
Thanks Clarence for your reply.
I have adjusted the bright field uniformity and it has helped a little and like you said, you normally do not detect it during normal viewing. I wondered if it would help to try to paint the laminate with Behr UPW flat to help eliminate this all together. Has anyone tried doing with with the DW laminate?
I was thinking about using a sprayer and this way I would be able to coat the material evenly without any marks from a fine nap roler.
Any thoughts on this??
Originally Posted by Clarence View Post
Hi Brian-
post #10 of 32
Brian one of the resident experts you need to talk to on the subject of painting the laminate is below: Send him a PM
http://www.avsforum.com/avs-vb/member.php?u=7607952
Name is tiddler and the thread you can read is here below:
http://www.avsforum.com/avs-vb/showthread.php?t=776981
post #11 of 32
Hello again,
Okay I went ahead and did something that most would think would be nuts but the hot spotting in the center of the screen was bothering me. Also, there was defiately some color shifting present as well.
For example, I have my Windows XP background color set to grey and you could clearly see in the center of the screen the affect of the hotspotting causing the colors to be an off grey near the center.
I went to HD and purchased a quard of UPW Flat interior. Had the guy shake up the paint really well and then got some very fine foam rollers so that when I applied the paint to the laminate it would be as smooth as possible.
I first cleaned the laminate with 91 percent isoproply alchohol to make sure there were no contamintents on the surface. I then applied 2 coats of UPW to the laminate waiting a few hours in between.
The results: My hot spotting issue is completely gone!! My grey XP background screen is perfectly grey without the other issues I was having before. Color and brightness uniformity appears excellent.
Regarding how the image quality looks, I think that I can say that with the DW laminate, the image perhaps was a bit smoother and more highly resolved. Also, the picture seemed to have more "punch" to it than now.
It seems in the DIY screen world there is no perfect answer. The DW laminate material seems to offer a better quality image/brighter and better resolved but with a slight hotspotting /color uniformity issue in my case. The Behr UPW flat applied to the DW laminate cures the HS/CU issues but doesn't have quite the PC the laminate offers so thats where I am at now!!
The only thing that I can assume is that with the UPW applied I now have basically a matte white unity or slightly under unity gain screen where with the DW material it was closer to a 1.3 gain screen. Also, the application of the UPW is not as smooth as with the laminate so this can be the cause of the image not being has highly resolved looking but this is all mere speculation.
Hi Brian-
post #12 of 32
Why did you not try using a Clear Matte Poly? You'd have solved the Hot Spotting, yet would also have retained the majority of the DW's best attributes.
Yep, you could have painted a piece of Drywall and gotten your results.
At least you seem happy to not see the hot spotting so you are ahead of where you were in that respect.
post #13 of 32
I could try that too!!! Luckily the laminate is very inexpensive and I can put up another one and test those results.
I have heard some say that with a clear Matte poly, it "softens" the picture?? Is there any truth to this? Also, where would you purchase this matte finish? Any part numbers??
TIA!!
post #14 of 32
Home Depot.
Behr Crystal Clear Matte "Water Based" Polyurethane
sorry....no SKU#
As for any "Softening" I'm certain that resulted due to over application of the Poly. It's not easy for a "1st Timer" to know when to stop applying, and harder still to apply it correctly.
Your only wanting to attenuate undue glare. Dilute the Poly with 20% distilled/purified water per volume, and spray it on in a "Dusting" manner, or use a 30% / 70% ratio and apply that with 'Ultra Smooth Finish" Foam Rollers. Either way, you use less Poly, and wind up with a thinner coating once the water evaporates out.
post #15 of 32
Here's a pic of the can.
I have two coats on my FG - I screwed up the first coat. As to whether it softens the picture, I'm sure the more you coat the more it would but I don't think it softened mine. What'd you pay for your sheet of DW? Just curious...
mech
post #16 of 32
Thanks guys for your replies. I will have to try this on my next DW laminate screen. I think I paid around 35 dollars for a 4 x 8 sheet. My screen is 92" Wide with a 1.85:1 A/R.
Perhaps it is because my projector is only 120" from the screen is why I had the issue with DW laminate while others report no hotspotting at all??
Does anyone know exactly what is causing this? Is the laminate too glossy hence the need to dull it witht the matte clear coat??
mech
post #17 of 32
Definitely share your source on the laminate. HD around here wants $2.14 a square foot for DW.
post #18 of 32
Just a local small shop in a commercial warehouse area here in Miami. They will take the laminate and cut it to whatever size you want for 5 dollars.
I don't think that they ship though as they just do local work.
post #19 of 32
WOW! That's cheap! Excellent job with regards to the footwork/research. It was always said to call your local cabinet/countertop shop...
mech
post #20 of 32
hmmmmmm...... that is abnormaly low priced....have you checked the back of your sheet for nomenclature? are you absolutely sure this small shop hasn't substituted your request with formica branded white which is known to hotspot?
post #21 of 32
That is probably for the thin stuff. Plus, he only has 32 sq/ft as opposed to the 50 or 60 that most are getting.
Brian,
You may want to go to the Wilsonart store directly. It is located in Doral near the Sam's Club.
post #22 of 32
I just recently paid $105 for a 5x10 sheet of the thicker DW 354-60 from Lowes delivered.
The local shop is either getting a heck of a wholesale price from Wilson Art direct or it is a substitute formica brand as you mentioned.
Brian, as Jim suggested exactly what nomenclature is stamped on the back of the screen material you have?
Also IMO if it is actually Wilson Art DW with a throw distance of only 10`ft. with a G90 that may well explain the hotspot issue. I only have a little puny Z5 at a 19`Ft. throw to a DW 120" diag. and I definitely dont have to worry about any hotspots !
post #23 of 32
I just checked my invoice. I actually paid 17 dollars for a 4x8 sheet of the DW laminate but they call it the LC version so it is half the thickness of the standard laminate. It is designed for vertical mounting which in my case was perfect. It is definately DW in color.
At the same time I also ordered another 4x8 sheet of the standard thickness DW just in case I messed up the thinner version. This one cost me 40 dollars. On the back of both laminates it does have a product code that I confirmed with Wilsonart as being their product.
post #24 of 32
Yup, it is the LC version Eric which I believe is half the thickness as the other version. The color DW is the same.
Brian,
post #25 of 32
I am picking up another 4x8 sheet tomorrow of DW but this time it will be the standard thickness stuff that everyone else is buying. I will report back to let you know what is stamped on the laminate.
My throw distance is on 121" on to a 90" wide screen so this might have something to do with the hotspotting/color uniformity issue. I think it is important to note however after painting the laminate with the Behr UPW flat, ALL of the hotspotting issues and color uniformity issues are GONE. Now, in a full white test screen it is completely white with no reflections of the CRT's in the middle like before.
As I have mentioned, the picture definately is not as "punchy" or vibrant as before but this might be remedied by a few clicks up in the contrast.
For me the jury is still out on which way to go. Whether to leave what I have up there and call it a day or to take it down and put up the other DW screen and deal with the hs. It is not like it was readily seen during normal viewing but if there were scenes in the movie such as one showing the entire sky or winter scenes, you could definately see it.
Another option is to just break down and order a Stewart Studiotek 130 and put this whole thing to rest but then again with my luck that will hotspot just like the DW!!
post #26 of 32
When you get your new sheet of DW you might want to try experimenting with a neutral density filter first before mucking with painting the DW.
post #27 of 32
My projector is a CRT so the NDF would not be applicable.
post #28 of 32
Brian,
Don't get a Studiotek. If you want to spend the money for a great screen, then give me buzz. Using some barium sulfate, we could spray a good screen.
post #29 of 32
Sent you a PM Eric.
post #30 of 32
MM, I want to thank you for your suggestion below. I went to HD and purchased the Behr "poly" top coat and applied it to the DW screen.
After letting the top coat dry after a few hours, all of my hot spotting and color uniformity issues are now GONE!!
I have read that some people felt that applying this material as a top coat will cause some softening of the image but I have not found this to be the case.
My question is now that this is applied, does this reduce the amount of gain of the screen? I beleive Clarence and others have measured the gain of DW to be close to 1.3 Does the application of the poly reduce this down to standard matte white levels of unity gain??
Are there any other "down" sides to using the poly on this type of material?
Home Depot.
sorry....no SKU#
  Back to Forum: DIY Screen Section
