AVS › AVS Forum › Audio › Speakers › best front speakers ~$1000 pair
post #1 of 2
Any opinions? I was thinking about Monitor Silver 5i's, Def. Tech 2006tl. Any help is much appreaciated, these will be used for modern rock (pearl jam ect.) and will be coupled with a center and surrounds (in the spring) from the same manufacturer
thanks
post #2 of 2
check out the klipsch reference series. You can get a pair for much less than 1000 and maybe buy a sub.
Also B&W 603 s2's are around 1000 a pair. check those out
  Back to Forum: Speakers
This thread is locked
