I've built an HTPC using ubuntu and mythtv, but I'm having a hard time connecting it to my TV. My HTPC has VGA and DVI outputs, and I have a DVI-Component cable. My 52" RCA HDTV projection TV has only Component input, no DVI or HDMI. When I connect the component cable I get a lot of garbage, looks like when you connect a monitor that's badly out of refresh rate or resolution, but none of the ubuntu resolutions work.
If somebody could tell me what I need to set to make this work, I'd really appreciate it. I'm sure there's a way to do it, I just don't know it.
Matt
Matt
